sway bar info checking
so guys i read this on the forum and was curious about the sedan how it says 03-04 have the smaller bar group A, but in group B it says 04-06 has the stiffer bar. How is the 04 in both sets. Does it mean that the 04.5's have the bigger bars then the regular 04??
well they aren't.
"G35sedan"
Group A
03-04 350Z all trim levels (car's without the revised suspension ONLY)
03-06 G35 coupe (all USDM production with oem 17 and 18" wheels)
03-04 G35 sedan (sport and non sport suspension's
All group A car's have the following oem sway bar specs
34mm front 21mm rear
hollow wall construction 5mm in thickness (courtesy of tomsn16)
Torsional rigidity Front: 1130lbs Rear:385 (courtesy BJ EVO350)
Group B
04.5-06 350Z all trim levels (car's with the revised suspension)
05-06 G35 coupe (all USDM production with oem 19" wheels)
04-06 G35 sedan (sport and non sport suspensions)
hollow wall construction 7mm front (courtesty tomsn16) 5mm rear
net change in front bar strength from 2mm increase in wall thickness
+17% (courtesty of tomsn16)
well they aren't.
"G35sedan"
Group A
Group B
Originally Posted by Joe_Camel
I think he meant to say 05-06 sedans are group B, no such thing as an 04.5.
rezendvous420
May 31, 2020 01:26 PM
vstypicals
Jul 20, 2015 10:55 PM
