Is there a camber kit for the G35x?
Old May 4, 2008 | 04:36 PM
G35xChicago's Avatar
is there still nothing out there? -1.8 and -1.2 in the fronts and dunno if i can get back into stock specs without a kit. i am just lowered on coupe springs....didnt think it would throw off the numbers so much...
i read somewhere, neal i think, did you custom fab it somehow and get it to work?
what do all you other lowered x guys do?
(yes i have read the lowering sedans thread probably 5 times now all the way through)
Old May 4, 2008 | 11:26 PM
seddon's Avatar
Dropped on coupe spring should not through your camber off that much. Get a better alignment guy.
Neal atempted the SPC A Arm but I don't remember the outcome do a search.
I'm dropped a 1.5" all around my front camber is within spec but my rear are off which I dont mind.
Old May 5, 2008 | 01:01 AM
jack_burton's Avatar
first a shout out to chi town boooom. Anyway i've heard the suspension on the gx is a little different which is the reason for the huge change in camber
Old May 5, 2008 | 09:59 PM
ttrank's Avatar
Grocery getter
Coupe springs on the X would be like Z springs on the RWD so that could be enough to put it out that far.
I don't believe the SPC front kit works on the X unless you swap out the entire A arm. There was a thread on it somewhere but I don't remember the exact details.
Jiggerjuice
Oct 5, 2015 02:33 PM
paolojericho11
Sep 11, 2015 07:08 AM
Dundermuffin666
Aug 14, 2015 04:01 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
