Lsd
Originally Posted by djkace77
Thanks for the mini review. Its just I have a 2003 and from my understanding and reading their is no VLSD or anything. So I am just looking at all my options. Thanks again. O by the way your front bumper is sick.
Originally Posted by G35CDUCK
So can a 04-06 LSD be put on a 03 AT sedan?
I know It will help me alot on getting out of my front yard!
Edit: and I think Kaaz...
Originally Posted by ttrank
I have a 3.3VLSD out of a 5AT coupe in my car. My sedan came with a 3.5VLSD rear end but the 3.3 helps a lot with high power/ high boost cars.
JUST KIDDING!!!!
I was the first G or Z owner to do a oem VLSD swap in late 2003. I made the mistake of doing the swap with parts and not a pumpkin swap. Keep in mind that the oem VLSD is good for slippery starts in northern winter climates, but does little to nothing for opening up the performance envelope of the car. It is not a proactive system, it has to allow slip to occur before it makes a attempt to rain in the offending wheel. It also will only resist so much torque before the viscous fluid is sheared past and it's a open diff again. If you want something that makes a differance, get a clutch type LSD or a torsen type.
Originally Posted by Rodrigo
^ when i was at the infiniti dealer getting my car i was informed that all PRE 04 had no LSD except the 6 sp.
And 04 and on , have LSD regardless of AT or MT.
I am sure there is LSD on all 05 - 06 G35. but the 04 im unsure of because it shares so many of the same parts as the 03.
No 2004 auto G35 sedan had VLSD, only the 2004 6mt has VLSD.
No 2005/2006 G35 sedan without the sport suspension has VLSD, all 2005/2006 6mt's and automatics with the sport suspension have VLSD.
I wonder if it would be worth it to install a Quaife in my car.
cost vs benefit I don't see the value... if you want to spend the $$$ though, it's nice to have... you'll probably get more value with your power - but it's still tough to justify the expense (IMO).
It is hard to justify the expense. Even with the 3.3 my rear end is all over the place in 1st, 2nd and lower part of 3rd right now. Sometimes the top of 2nd and all of 3rd has grip.
I think for the few times I need the extra grip it is not worth the cost. Maybe down the line but yes, I need to get some stuff paid off for now.
however – keep your eye out for the AutoTech (Quaife America) version… it might be more reasonably priced… and maybe by the time it’s out some of your current stuff will be paid down…
hmmm, thats wierd i've got an 04.5at and when im on high slants and what not i can feel my rear end stall out, which would lead me to assume the lsd isnt there? whats VLSD? and would it be worth it to hop onto the tomei lsd?
