q45 headlight retro fit
Old May 20, 2008 | 11:21 PM
RST531's Avatar
I knew someone did this mod on a coupe. well i found the pixs so you guys can take a look at them.
Attached Thumbnails q45 headlight retro fit-q45piaadark.jpg   q45 headlight retro fit-q45piaaheadon.jpg   q45 headlight retro fit-q45piaaoff.jpg
Old May 20, 2008 | 11:24 PM
gtrefever's Avatar
where do you actually get the projector like the circles
Old May 20, 2008 | 11:31 PM
naughty240's Avatar
^ its from an oem Q45 light. They have the circles
Old May 20, 2008 | 11:57 PM
JDM_Cain's Avatar
nice mod
Old May 21, 2008 | 12:29 AM
05 sedan's Avatar
now to find someone to do the work and not charge you an arm and a leg
Old May 21, 2008 | 11:42 AM
ttrank's Avatar
Grocery getter
Diy...
Old May 21, 2008 | 12:18 PM
gtrefever's Avatar
how much do the lights go for...
Old May 21, 2008 | 12:21 PM
fstrthnlfe00's Avatar
http://cgi.ebay.com/ebaymotors/UNIVE...spagenameZWDVW
Old May 21, 2008 | 01:46 PM
ttrank's Avatar
Grocery getter
Originally Posted by fstrthnlfe00
Those don't look like real Q45 projectors. The ouput is never anywhere near as good with the knock-off ones.
Real Q45 projectors will run anywhere from $300-500 for a pair.
Old May 21, 2008 | 01:47 PM
You are probably right. However, for those looking for a cheaper solution I'm sure it will be fine. As for me, I'm fine without Q45 projectors... or any projectors for that matter.
Old May 21, 2008 | 01:48 PM
ttrank's Avatar
Grocery getter
Would you be ok loosing output over the existing reflector oem setup?
Also can you even run D2S bulbs in those?
IMO the only way to do a projector retrofit is the right way the first time with no regrets.
Old May 21, 2008 | 03:40 PM
g35freak86's Avatar
I second that. That goes along for the whole moddin process as well. Save up and get what you really want instead of settling for something that you'll be happy with for a couple weeks or so
Old May 22, 2008 | 02:03 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
why do people do the acura-mod lights?
is it to get xenon lights for non-premium bitches?
Old May 22, 2008 | 08:12 AM
itgogitrev's Avatar
Because Acura has some of the best projectors out there. Well... Stanley has some of the best projectors out there and puts them in Acuras.
It puts down the light so much better than reflectors, premium or not.
Old May 22, 2008 | 09:38 AM
  #30
godmans's Avatar
For output, go with the TL's bi-xenon projectors or the S2000/ TSX's low beam projectors.
As of the Q45 projectors, the geniune ones are north of $300+ for sure
