taking off shifting circle
Old Apr 16, 2004 | 01:46 AM
subrobo's Avatar
Hi, i was just wondering how to take off the aluminum shifting cover? because someone spill coke in it...and its sticky...=_=
Old Apr 16, 2004 | 01:49 AM
subrobo's Avatar
Re: taking off shifting circle
Ops, forgot to mention...its a AT G35
Old Apr 16, 2004 | 07:06 AM
cato's Avatar
SouthernComfort Moderator
Do a search. I remember reading a thread on this a long time
ago.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old Apr 16, 2004 | 09:27 AM
gspot35's Avatar
Speaking of removing the circle. I had an idea the other day to take the circle off and replace with a shifter boot. What do you guys think? Anyone done this?
03 Sedan~5AT~19" rims~Garnet~aero~premium~sport~Stillen Cat-back
Old Apr 16, 2004 | 09:33 AM
cato's Avatar
This has been done. There is a thread on this some time ago.
It looks really good. Our 5AT shifter looks like a MT shifter.
Way cool.
Old Apr 16, 2004 | 09:51 AM
jasijay's Avatar
I actualy just got done taking mine off to add some AV equipment. What you need to do is: First, take off the gear shift ****. Insert a flat head screw driver in the space in the lower part of the shift **** and sepreate. Be carefull NOT to loose the little metal clip that is in there as I did! Then, near the back part of the console (if you have heated seats, it is behind them but before the arm reset) grab the sides of the console and pull out to disengage the clips. Once that is off, carefully lift from the back on an angle as the front 'lip' of this piece sits below the radio housing. Then, disconnect the wires for the various parts. And your done!! One thing though, be VERY carefull. The shif housing has to 'pole' looking plastic pieces that can break real easily. These 2 pieces drop into two small holes so the round piece does not move around. I do appologize for not having pictures of this. I just got done installing TV's, DVD palyer and the like. I will post pictures in a week.
Old Apr 16, 2004 | 10:33 AM
cato's Avatar
Found the thread. try this:
https://g35driver.com/forums/showfla...psed&sb=5&=all
page 18 on Technical and Modifications .
12/21/03 thread started by jays_g
JG_G35
Accessories
Feb 25, 2016 01:44 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
nervseele
Jul 17, 2015 11:21 PM
