Compression-Rod related noise? or not (says the dealer)
Old May 22, 2008 | 03:24 PM
BiGZdotORG's Avatar
So I've been dealing with a nasty "clucking" noise whenever I go over bumps (even the tiniest ones) - and I'm fed up.
I always chalked it up to being the compression rod because of all these problems I hear about - however, when I called the dealer in my area, they said that the compression rod TSB only addresses the creaking noise (which I do have), whereas the clucking noise is something completely different - which actually involves changing the lower compression rods.
Could anyone confirm this? and if so, anyone have a cheap(er) alternative to fix this? I need to replace one, if not both of my front rods which isn't going to be cheap.
I did a search here and my browser keeps timing out, hopefully this has not been answered already.
Thanks
Old May 22, 2008 | 03:41 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
"clunk" is classic C-Rod noise...
The dealer is BSing you about creaking noise.
Creaking noise is more sway bar needing lube noise
Old May 22, 2008 | 04:18 PM
Hotdawwgman's Avatar
yeah. i have a question, i bought my car at Carmax and picked up their extended warranty, and i have the option to go to an outside source. How do i get my compression rods fixed but want it covered under my warranty with Carmax. if i had known this before i had bought the car, i would of had them take care of this when i bought the car 3 1/2 months ago!!
Old May 22, 2008 | 04:45 PM
joedaddy1's Avatar
if you can take to any shop, y not just take it to the dealership?
they fix ur car with OEM parts, and carmax pays..
everyone is happy.
Old May 22, 2008 | 07:21 PM
k@osx71's Avatar
how many miles you guys have? if it's still under warranty, take it to the dealer. I had mine replaced under warranty as well as may rear sways.
Old May 22, 2008 | 08:10 PM
BiGZdotORG's Avatar
mine is no longer under warranty (200K+)
so, this is definitely the compression rod issue on the TSB?
Blue Dream
Dec 5, 2015 10:56 AM
alinero718
Sep 27, 2015 09:35 PM
doakley92
Sep 25, 2015 12:58 PM
socaldavid
Sep 5, 2015 04:35 AM
