Front Camber kit Necessary?
Old May 29, 2008 | 09:07 AM
gmaxim's Avatar
I just installed springs, shocks and rear camber kit. My question is, are the fronts that necessary? I took the car in for an alignment and was able to get the fronts in spec. I searched the forum but wasn't able to find any info on how important the fronts are.
Old May 29, 2008 | 10:07 AM
Mmagic76's Avatar
If you're in spec then you don't need a camber kit.
Old May 29, 2008 | 10:48 AM
LuXXXz's Avatar
im not positive but depends what kind of springs and shocks you're using you. for example
if you're using coupe springs you have to get the car to coupe specs!!!
im not positive about this
someone chime in!
Old May 29, 2008 | 10:54 AM
G35Papa's Avatar
If you're dropped less than an inch, you will most likely not need camber kits and should be able to get back into spec.
The G has some rear camber adjustability from the factory. The front has none.
Old May 29, 2008 | 01:16 PM
ttrank's Avatar
Grocery getter
I have had a SPC front camber kit sitting around for ~12+ months and never put it on. I think I'm just going to sell it.
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
