Headlight Shake
Old May 31, 2008 | 06:30 PM
bios2k's Avatar
Headlight Shake
Hi, I have a 2003 G35 with HID Headlight.
When I fallow a car I see my light beam reflection on the other car shake when hit small bump on the road.
I've check quickly and my headlight seem to be correctly bolted. I think is the Inside that shake.
Does anyone have this problem? is there a solution?
I've changed my Bulb and I know that they are correctly tighted.
Old May 31, 2008 | 07:20 PM
chinee's Avatar
That's the way it is... you'll get accustomed to it in no time.
Old Jun 1, 2008 | 05:04 AM
Joe_Camel's Avatar
Mine shake a little too, nothing to be concerned about.
Old Jun 1, 2008 | 02:02 PM
Hotdawwgman's Avatar
o yeah mine does that too!! Ok cool no worries!!!!!!
Old Jun 1, 2008 | 06:23 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Mine too. I've had the dealer check it out a couple of times and that is how the assembly is designed. I believe the '05 had a design change to correct this.
but like mentioned before, you will get used to it.
Old Jun 2, 2008 | 01:24 AM
jakeup93's Avatar
Mine shake as well...more than what I think is normal. On smooth roads its not a problem but when I'm on a road with many small bumps I can tell that the headlights are bouncing like crazy. I know that it's annoying for other drives. I opened things up to check it out and the lights were just designed that way. The actual headlight is supported by a weak metal piece while the bulb and the reflector are too heavy and will bounce around. If I hit the headlight with my hands I'll get noticeable shake. What I did was take several layers of cardboard fully wrapped in electrical tape and used it as a backing support against the back of the bulb. It is supported by the back cap and I made sure it stays tight. It has helped a good amount but it's not the perefct solution. No electrical worries/problems so far, its been about a week.
Old Jun 3, 2008 | 10:08 PM
bios2k's Avatar
Good, Thks
It,s noting to worry
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
