Motordyne Plenum Spacer Install
Old Jun 1, 2008 | 12:44 PM
eric300zx's Avatar
Yesterday, I got up early to start installing the spacer so that I could use the car in the afternoon. Wanted to have the engine cool as per the instructions to make it easier to remove and torque the bolts properly.
I started with the removal of the engine cover, battery terminal, Z tube and then, the plenum bolts. All bolts came off pretty easily, a little hard to reach since I have a bad back except when I got to the rear guide pin for the lower plenum, the thing wouldn't turn a smidge using a 4mm socket-I stripped the pinhead. Tried to soak it with WD40 to help loosen it up - no luck!
I then thought, a vise grip should do the trick. Again, no luck in removing the guide pin. The thing is just frozen. 3 hours later, it was still not cooperating. Most of the thread is gone by this time plus the visegrip teeth is also marred.
At this point, I was just ready to give up due to the frustration. I figure I would just have to install the top spacer and skip the lower ISO which I did.
So what would be the best approach to fix my problem? Drill out the pin carefully, is this possible? I really would like to install the lower gasket.
Thanks all and sorry for my rant!
Old Jun 1, 2008 | 01:11 PM
ModMe's Avatar
Here's what I did, sand 2 opposite side of the bolt flat so you can get a good flat grip. Use big flat pliers to twist itoff.
Old Jun 1, 2008 | 01:36 PM
eric300zx's Avatar
Yeah, I am cooking this idea too but not too excited because the vise
should have worked. It just tells me how tight it is in there but definitely worth a try. I will file it to make it flat but I think I would end up snapping it
off.
Old Jun 1, 2008 | 06:29 PM
LMG_35C's Avatar
If you still have threds left you could screw two nuts onto the pin and then lock them together about 3/4 way down the pin but close to the top of the lower plenum. You then use a wrench on the lower nut, CCW, to remove the pin. Get real penetrating oil as WD-40 just doesn't cut it for tough stuff like you've run into. Good luck.
Old Jun 1, 2008 | 09:53 PM
eric300zx's Avatar
Hi,
Before I went with the vise grip idea- this is what I had in mind. I tried this method using the stock nuts as mentioned in the instructions but I could not even thread the second nut as there was not enough thread/pin not long enough. Now , there isn't much thread left.
Old Jun 2, 2008 | 08:46 AM
Mmagic76's Avatar
You might have to drill it out, I think they sell these things that you drill into and it has teeth that bite into the screw that unscrews it out. Check out the hardware store.
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
