Check Disk
My CD changer stopped working. I turn the car on and it will read CD1-1 and then nothing will happen. About 15 seconds later it will switch to CD 2 and nothing will happen, then 15 seconds again it switches...so on and so forth all the way until CD 6. Then it just says CHECK DISK and I can't even switch CDs or anything. I tried it with burnt CDs as well as production CDs and nothing works. I know the CDs work, too. The CD player itself worked fine this morning then all of the sudden stopped.
Any suggestions or experience with this? I don't want to take it to the dealership because they will charge $60 just to look at it.
Thanks!
Thanks!
Your CD player is toast most likely. I just had this problem 2-3 weeks ago with my 06 coupe. Tried to clean the laser, use non-burned CD's, and everything else I could think of to resolve the issue. Nothing worked. Took it to the dealership and they replaced it free of charge. My friend who has 07 G sedan also encountered this problem last week. Same outcome. Dealer had to replace his player as well.
I'm honestly not sure how long electronic components like the CD player are covered under warranty, but I'm sure they'll confirm for you if you give them a call. Sucks your nearest Inifiniti dealer is 2 hours away! Good luck with the repair. Hopefully it won't cost you anything, but 2 hours each way in gas is no cheap bill these days!
By the way, my friend's infiniti dealer said the malfunction was caused by burnt CD's, which I was also using in my CD player when it freaked out, but who doesn't use burnt CD's these days? Looks like a manufacturing flaw with the reader.
UPDATE: Called Infiniti and gave them my VIN# and they told me that it was still covered under warranty. They went ahead and ordered a new one and should be in next week. Thanks 'Nasty' for your help.
^That sucks man...this is definitely the thread where CD players go to die. Good luck on getting it replaced for free. Seems like there's a pretty good chance since I haven't met anyone who had to pay yet.
i am out of warranty..
i probably play the cd player once a month MAX too.. dangit
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Machine Head
Sep 4, 2015 07:22 PM
