Gas pedal vibration - Arrrrrrgh !
Old Jun 18, 2008 | 06:19 PM
hg35x's Avatar
My gas pedal vibrates while driving at a constant speed as if in synch with the engine and it is very annoying. Has anyone found a fix for this, experienced this? Arrrrgh !
Old Jun 18, 2008 | 06:26 PM
MikeYo's Avatar
never felt this on any of our cars.
Old Jun 19, 2008 | 04:03 AM
gtbigup01's Avatar
Nope but my clutch vibrates when my wipers drag across the windshield.
Old Jun 19, 2008 | 10:51 AM
Hotdawwgman's Avatar
mine vibrates because of my Subs!!!
Old Sep 1, 2010 | 10:18 AM
AARONHL's Avatar
Any fix for the vibrating gas pedal?????
Old Sep 1, 2010 | 11:44 AM
Well, I dont have the subs in my car anymore!
Old Sep 1, 2010 | 12:07 PM
hg35x's Avatar
It seems to have gotten better. The drive by wire module had been replaced and I think the new spring could have been rubbing or something.
Old Sep 1, 2010 | 12:36 PM
WILLIE BEANS's Avatar
i did have a vibration in my gas pedal . whene i braked .
my mechanic told me it was my rotors .
i got new rotors all around and it went away ..
but it could be something in your suspension needs replacing if its not just during braking ..
have someone check your suspension and/or rotors ..
Old Sep 1, 2010 | 01:48 PM
b-dRizZy's Avatar
i agree with
ima-g-rider
could be brakes, rotors, or supension .. or also maibii alighnment .posible
Old Sep 1, 2010 | 05:57 PM
hg35x's Avatar
It's not the brakes/rotors. Just minor vibration. I was thinking it was the return spring rubbing against it's bushing on the throttle pedal - I do think I need compression rods because when I leave my driveway I have a concrete curb and I hear this squeak in the front end when going over the curb. I have to have that checked out.
Old Sep 2, 2010 | 01:40 AM
626Gthirtyfive's Avatar
Are our 6mt shift ***** supposed to vibrate? Sorry for hijacking thread didnt want to start a new one for such a simple question..
Old Sep 26, 2011 | 11:41 PM
AARONHL's Avatar
BUMP
My gas pedal vibrates at any speed, but more noticeable the faster I go. It's pretty much like I have a foot massager down there which causes my foot to fall asleep during a 20 minute highway drive.
I know our pedals are not directly connected with anything other than a electronic wire. I feel bumps, cracks, thumping like the gas pedal is connected to the wheel hub.
This is so annoying you have no idea.
Old Sep 27, 2011 | 12:38 AM
05_SkylineSedan's Avatar
20 Year Member
Originally Posted by AARONHL
I know our pedals are not directly connected with anything other than a electronic wire....
That's the thing, there is no physical cable or anything which can cause the accelerator pedal to move on its own (no motor, etc.). It's just a spring loaded lever that turns a potentiometer sending a control voltage to the throttle valve - which is supposed to follow your foot. Below is the illustration from the service manual (05/06). It is bolted to the firewall though so I would think any vibration you feel in that pedal must be coming through the body of the car. That's why folks here are suggesting brakes or suspension. It would be nice to be able to touch the firewall with your foot to see if you can feel it directly, but don't crash!
Old Sep 27, 2011 | 01:33 PM
Mustang5L5's Avatar
Only time my pedal vibrated was when my front wheel bearings were junk
After i replaced them...vibration free!
Old Sep 27, 2011 | 07:19 PM
AARONHL's Avatar
I made sure everything was tight including all wires near the gas pedal. My wheel front wheel bearings are only about a year old.
