So you want to swap out your sedan seats ?
Old Jun 23, 2008 | 01:31 AM
sweettalker's Avatar
SWEETTAKLER DIY: So you want to swap out your sedan seats ?
Well I bit the bullet and got some bride seats for my sedan. The seats came with sliders so i had Wedge engineering make me brackets to bolt up to my car. For all those people who were wondering if 350z seats will bolt up to the sedan, it will. They didn't have templates for the sedans so i used the template for the 350z/g35 coupe (they were the same). I knew they would be lower than my stock seats But PREPARE YOURSELF IF YOU PLAN ON DOING THIS !! BOY OH BOY THEY ARE LOW as HELL!! I could barely see over the dash let alone see the end of my hood.but then again my stock seats were really high to begin with from the factory. I've had them for a month now and I'm slowly adjusting the lowness of the seats, but I'm going to have to get longer bolts and spacers to push up the seat some. i'm 5'11 and it's still too low for me (maybe some like it like this but I don't feel comfortable this low and it doesn't feel safe since it bothers my viewing out of the car).
Pictures to come.
BTW, anyone know where i can get some longer bolts that will bolt up to the chassis? I've tried autozone and pepboys but they do not have it. it is size 7/16-4 FINE. Or if anyone knows the correct size, please let me know, I can't find it anywhere. Thanks in advance
Cig box as a preference to see the level it sits at from the shifter
How low it is off the floor
The top of the plate is touching he ceiling and the bottom part of the plate is touching the seat to see the head clearance
Seats
The driver side seats a little bit lower than the passenger side. Pass side is perfect i wish the driver side was the sam height
There are only 4 bolts holding up the seat. If you look on the floor, there is two in the front and two in the rear, both 12mm. You can use a regular socket wrench but you will need help of a flathead screwdriver to pry/unhook the power/heater seating function attached to the stock seats. ENJOY !
Old Jun 23, 2008 | 01:34 AM
w33ps's Avatar
I'm 6'5 and think this might be a good option! Can't wait to see pics.
Old Jun 23, 2008 | 11:47 AM
Hotdawwgman's Avatar
Old Jun 23, 2008 | 12:22 PM
Klubbheads's Avatar
i wonder how much lower it sits compare to coupe seats.
Old Jun 23, 2008 | 12:35 PM
rookie's Avatar
[QUOTE=sweettalker
BTW, anyone know where i can get some longer bolts that will bolt up to the chassis? I've tried autozone and pepboys but they do not have it. it is size 7/16-4 FINE. Or if anyone knows the correct size, please let me know, I can't find it anywhere. Thanks in advance[/QUOTE]
You sure it's a standard thread? I would think Metric would be correct.
Local can't beat mcmaster-carr http://www.boltdepot.com/default.aspx
On the east coast but they have a huge selection. http://www.boltdepot.com/default.aspx
Old Jun 23, 2008 | 02:57 PM
Qbrozen's Avatar
Heck, as it is, my head is very close to the roof (also 6'5") and I have to slouch way down in the seat when wearing a helmet at the track. So this could be a great option.
Maybe someone can help out a newb, but what are "bride seats"?
Would power heated seats hook right up to the stock sedan wiring? I would think so, but would want to know for certain beforehand.
Old Jun 23, 2008 | 08:32 PM
OCG35's Avatar
and King Bolt in Covina, CA (626) 339-8400... they have every damn thing you could ever need! Saved my @ss when needing specific washers, bolts & spacers installing custom engine cover.
Old Jun 23, 2008 | 10:40 PM
darrick's Avatar
pics please
Old Jun 23, 2008 | 11:08 PM
G35Papa's Avatar
^+1
Old Jun 24, 2008 | 01:58 AM
ttrank's Avatar
Grocery getter
I got my longer bolts at Home Depot. They are metric, I don't remember the exact size.
Old Jun 24, 2008 | 02:38 AM
Beebo's Avatar
we want pics...
Old Jun 24, 2008 | 06:25 AM
Really? I took the stock bolts to homedepot trying to search for the right size. They were non existant. i even screwed in the stock bolt to the sample holes that they have on display and it didn't fit any of them. If you could findout the size that would help me out alot!
And yes, the pics are coming i just have to upload them.
And "bride seats" are non heated, non power, and non leather. They are race seats that are reclineable. The brand is called BRIDE.
Old Jun 24, 2008 | 11:10 AM
Qbrozen's Avatar
ooohhhhh.... see, your comment about "whether 350z seats will bolt into a sedan" threw me off. I thought you meant seats from a 350z. Now I see you meant aftermarket seats designed to fit the 350z.
Old Jun 24, 2008 | 04:58 PM
teedo's Avatar
if you're going to get a bride seat, get an expensive one. something that will actually look good in your car! it's a luxury sports sedan not a 240
Old Jun 24, 2008 | 06:31 PM
Well there are no aftermarket seats designed to fit the 350z per say. You can pretty much get any seat out there and all you need is brackets for a specific car to fit that certain car. 350z brackets fit in my g35 sedan means 350z and g35 sedan and coupe all have same brackets which means that it will all be interchangeable. I don't know about the power/heat being plug and play but seats physically will fit with no problems (no cutting no welding). PICS have been updated !
BTW, i DID get expensive brides. I got the rear painted black to match my interior. I actually was going to get it painted white but doing so would show every scuff and dirty mark because my passengers probably wouldn't care for the seats as i would. so i decided on black where you can't see the blems and scratches as much as white.
