Blown Strut
Old Jul 6, 2008 | 07:13 PM
jimmykce1's Avatar
Blown Strut
I have been getting an occasional squeaking sound front of the car. When I get out and push down I can get the sound to make the sound again. Is this a blown strut??
Old Jul 6, 2008 | 07:34 PM
Mr.GEE's Avatar
20 Year Member
Some are having problems with the lower arm rubber bushings failing making a squeeking noise. There was a thread on this a few days ago, I see if I can find it.
Old Jul 7, 2008 | 04:12 AM
gtbigup01's Avatar
When your struts are bad or blown don't they bounce excessively when you push down on the suspected side?
Old Jul 7, 2008 | 06:59 PM
jimmykce1's Avatar
This may be my problem. I will get my mechanic to check it when I have it in for an oil change. Its easier to look when its on a lift.
Old Jul 7, 2008 | 07:23 PM
Klubbheads's Avatar
relube the bushings of ur front sway bar, it is the sway bar bushings not the shocks, that are making that noise.
Old Jul 7, 2008 | 08:33 PM
jimmykce1's Avatar
I put on new bushings with my sway bars and the noise started before the sway bars were installed.
Old Jul 7, 2008 | 10:59 PM
itgogitrev's Avatar
Is it a high pitched squeak, a creak, or a lower groan? If it's a creak, it might be your compression rods.
Old Aug 12, 2008 | 03:41 PM
CHILLIN858's Avatar
in the rear of mine the left and right side are making a high pitched sqeaking sound.. when i get in and out of the car... and also when i push down the back corners...
my shocks are gone right?
anything else i should be worried about?
Old Aug 12, 2008 | 04:02 PM
Jeff92se's Avatar
Red Card Crew
My CA bushings squeak/creak like all get out. But I've looked at athem and they don't seem torn. Wish energy would come out with poly replacements
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
Claudiu
Sep 26, 2015 01:04 PM
