Fellow g35 oeners need rim help and opinion.....
Old Jul 7, 2008 | 06:17 PM
Pearlwhite4dr's Avatar
Would a staggered 18x7.5 +30 18x10.5 +55 SSR Professor SP1's in black with a polish lip fit a g35 05 sedan without rubbing? and what tires should i put? the car is not dropped yet but will be.......right now it is on coupe 19s.......thanks
Old Jul 7, 2008 | 06:44 PM
my05g35sedan's Avatar
Yes and No
The front would fit with a 215 - 225 series tire but the 10.5" +55 will hit the rear suspension. A 10" +55 would work but you would have to really stretch a much smaller tire and even then you would only have 4mm clearance on the suspension.
An option would be to run a 5-10mm spacer on the 10.5" rear but then you are looking at the added cost of the spacers, longer wheels studs and rear camber adjustment arms to get it under the car.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
laksjd84
Jul 24, 2015 05:12 PM
