Jack Stand Adaptors...
Old Apr 29, 2004 | 02:27 AM
thegr8tg35's Avatar
For those who use jack stands, what adaptors do you place on the stands in order to put under the pinch welds? Where did you get it? Thanks!
<P ID="edit"><FONT class="small"><EM>Edited by thegr8tg35 on 04/28/04 11:28 PM.</EM></FONT></P>
Old Apr 29, 2004 | 08:08 AM
G35_TX's Avatar
Re: Jack Stand Adaptors...
I don't use any. I jack the front up with the tie down hooks that are behind each wheel in front. Those are strong and will hold the car fine. The rear I just used the flat space on the bottom of the suspension near the tire where the spring sits on.
Old Apr 29, 2004 | 11:04 AM
MiamiG35sedan's Avatar
After an exhaustive search, I could not find true jack stand adapters like those listed in the big service manual (you can view this under Jacking Your G thread in the DIY section). It turns out that these adapters and their part number are not available in the USA, only in Japan. I did find a hydralic jack adapter which works well to jack up the car. Once jacked, I place my standard jack stands under the inner frame rails behind the front wheels for the front, or under the seat pan reinforcements for the rear. So far, this has been safe and has not caused any damage.
2004 Sedan 5AT
Desert Platinum/Graphite/Sport Tuned Suspension
Huper Optik Ceramic 50/Underbody Diffusers/Clear Corners/GroundingGear 7 Wire/Z-Tube/Stillen High Flow Airbox
Old Apr 29, 2004 | 01:05 PM
townsley's Avatar
I spent a LOT of time searching these out. Though some links to products were provided as a result of my many queries on this forum, I could find nothing that would work - either the adapter didn't fit my stand, or the adapter didn't mate with the jack points properly. Here's what I did when using Jack Stands on my Sedan for a suspension upgrade:
I bought a box of shop towels and folded them lengthwise in half, and then in half again. Then, starting at either end, I rolled the ends toward each other until they met in the center. What I ended up with was 2 tight rolls with a cleave down the center. I placed this on the jack stand with the cleave facing up. Then, when I lowered the car onto the stand, the rail sank right into the cleave and the 2 tight rolls against the underside of the car. There was no grinding, no scratching, no damage of any kind - worked like a champ!
-townsley-
2003.0 Premium BS/Willow 5AT Sedan
ZTube/K&N Filter/Sport Suspension
Grounded/Tinted/Splash Guards
Lip spoiler/Aluminum Pedals
Battery Disconnect Switch
Old May 2, 2004 | 02:01 AM
thegr8tg35's Avatar
Cool, thanks for the tip...
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
toadfire
Sep 21, 2015 07:15 AM
