Remote controlled windows
I have a 2003 G35 sedan. Using the remote, I am able to get the front windows to roll down. Am I supposed to be able to get the back ones to go down as well? What can I do to fix that? Also, is there a way to use the remote and make the windows roll back up?
If you have base model, only the front two windows roll down. Premium package all four windows roll down...if you put the key in the door lock, and turn to the right and hold, the windows will roll back up
If you really think about it, rolling up the windows with the remote is needed. You roll down the windows to air it out, then get in and drive. It's a not a hassle to roll them up again since only the auto windows roll down.
If your rolling them down to reach in and grab something, your already at the window with the fob in your hand, so just pull out that key and roll them up.
http://www.kptechnologies.com/
Go under products and window roll up.
As the others have said you need an aftermarket module to roll them back up. I have an aftermarket DEI module on my alarm that rolls them up.
also you cna control how far down you want your windows to go when holding it anywhere form 5-10 seconds lol just play aroudn with it
Originally Posted by maciejk
hehe yeah, i bet if u press the lock button and hold it they will roll back up as well, hehe i'm going to try it no matter what.
Originally Posted by snotf
its stupid to take your key out to insert it again to roll up... makes me wish i had $ to spend on silly things like roll up modules!
