Should I take to dealer for inspection?
Old Aug 22, 2008 | 01:13 PM
g35fanat1c's Avatar
When ever i start the engine and then press the gas pedal, I hear a little clunking noise or like a noise of like some metal hitting each other in the engine. This only happens for like ~1 or 2 seconds and this only happens when I start my engine and start going.
Should I give Infiniti a call to take a look at it? Also, When I go over a speed bump, It sounds like air is coming out of my tires, as I hear a hiss. Is that normal?
Sorry for the noob questions.
Thanks everyone for your help.
Old Aug 22, 2008 | 01:19 PM
lexusk8's Avatar
The first noise you explained when driving off after starting engine most likely refers to the ABS undergoing a check on the system. This is completely normal on all G's after going 10 mph, so you have nothing to worry about.
The second noise when going over a speed bump might be coming from your compression rods and/or the bushings. This is common on all G's. Since you have any '06, you can call the dealer and ask to have the compression rods checked and/or replaced under warranty.
Old Aug 22, 2008 | 01:27 PM
G SEDAN's Avatar
the clunk can also be the timing chain at startup
Old Aug 23, 2008 | 12:20 PM
LEON NYC's Avatar
Bro, you have warranty, whenever I feel there's something defective I make an appointment asap, let them know you need a loaner in advance, and let them handle your worries, and don't take it to a dealership for an inspection, it takes 10 mins at a private mechanic shop...
Old Aug 23, 2008 | 02:36 PM
g35fanat1c's Avatar
So I should not take it in to the dealer for inspection? Should I just go to the dealer and ay that I am hearing a clunk and not use the word inspection?
Thanks!
Old Aug 24, 2008 | 01:23 AM
LEON NYC's Avatar
just follow what i posted about what i would do,and you'll be alright kido
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Gabe83714
Oct 6, 2015 06:40 AM
