How long is the original antifreeze designed to last
Bought my 05 G new in April of 05 and I still have the original antifreeze. I understand Toyota uses long life antifreeze designed for 100K miles. Just curious if I can get through the winter without changing my antifreeze. I plan on getting a new G in the spring.
http://www.partsource.ca/doityoursel...ator-flush.asp
http://www.advanceautoparts.com/engl...20010501rm.asp
http://leemyles.com/articles/a-few-e...iator-and.html
three sits, the first two say yearly, the last says every two years.
i would recommend to do it yearly, i personally flush my radiator every spring.
never listen or fall for the "lifetime" crap, in the '80s saab said they invented an engine that dosent need to have its oil changed...pssh that worked very well
good luck!
good luck!
Originally Posted by 6spSEDANFTW!
also depends were u live, say California vs North Carolina, so 30k isnt always the best
Originally Posted by bythabay
factory fill is good for 4yrs/60k. Every time thereafter it's 2yrs/30k.
should be every 1 1/2 year or 15k miles. id say pick up the maintenance schedule from dealer and just perform it yourslef or bring it to your personal mechanic and have them do. alot cheaper. certain things like tb cleaning the mechanic should know not to do due to iavl. im pretty sure he would know a tech that can perform this though. manual iavl procedure is a hit and miss due to no learn confirmation as opposed to consult. btw this is speaking from a nissan tech standpoint. not 100% sure about infiniti's.
pretty much any GREEN antifreeze and make sure its a 50/50 mix (50% antifreeze 50% water) dosent matter if u bought a 50/50 mix already, or buy the 100% and do the 50/50 urself, dosent have to be perfect.
Thanks man. I'm glad it's a pretty regular coolant. Now I don't have to stock that weird-azz G11 and G12+ like I needed to for my VWs.
