Clock Light seems very dim? & Passenger Heated Seat Button out
Old Sep 21, 2008 | 09:29 AM
Brian S's Avatar
Hello,
After purchasing my car yesterday (04 G35 RWD Sedan), I had a chance to do some night driving and found that the Clock light seems VERY dim. Also, the light for the passenger heated seats button is completely out. Is the dimness of the clock light like this in every other g35 sedan? If seems that there is only ONE bulb for the clock which is on the right side of the clock illuminating the whole face of the clock.
1.) Is there any way I can integrate an LED to light up the face of the clock? Maybe go with an indigo/blue color or even a superwhite? The color of a regular light bulb is boring!
2.) Is there an easy fix to replacing the light under the passenger heated seat button?
Any help is appreciated for a noob like myself!
Old Sep 21, 2008 | 11:46 AM
Noremac's Avatar
Originally Posted by Brian S
...the Clock light seems VERY dim.
You may have a bulb out, but the clock is somewhat dimmer than the rest of the instrument panel lights, especially if you like your IP on the dim side. When you raise the brightness all the way, is it still very dim?
Which light are you talking about? There are two: one for background illumination, and one for heat-on indication. Both are replaceable, but will require some disassembly of course. Do you have access to the FSM? Check section IP (instrument panel).
Old Sep 21, 2008 | 07:27 PM
Brian S's Avatar
I guess it gets brighter.. but still looks too dim for my standards.
I was talking about the one that stays on, the background illumination.
Old Sep 22, 2008 | 12:41 PM
davidm99's Avatar
20 Year Member
Sedan
clock light
As for your clock light this has been discussed numerous times and if you search several threads will show up but here's a link to one of the threads:
https://g35driver.com/forums/lightin...ent-guide.html
It talks about replacing with a new bulb but later on there are mentions of how to replace with a LED.
Old Sep 22, 2008 | 01:33 PM
Mmagic76's Avatar
Blubs in the switch are not sold seperately, most likely you'll need to either buy a complete switch or take it apart and find the bulb at a local electronics store.
Old Sep 22, 2008 | 09:29 PM
Brian S's Avatar
Thank you!!! Exactly what I needed...
arora_g35
Apr 16, 2026 02:52 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
