Intelligent key question again..
Old Oct 3, 2008 | 10:18 PM
eagleee's Avatar
I have one intelligent that came with my 2005 infiniti and i just purchased another one from ebay. How do I program it? Is this the right instructions for the intelligent key (http://www.infinitihelp.com/diy/comm...am_key_fob.htm?
Old Oct 3, 2008 | 10:44 PM
speedracerg35's Avatar
you have to take it in to the dealership. they usually want both fobs together. i believe the instructions you have are for a standard fob.
Old Oct 4, 2008 | 10:47 AM
eric300zx's Avatar
Sorry, I can't help you but can you tell me which seller you bought the key from? I think Speedracer is right, you have to take it to the delaer so that they can program it for you. Thanks!
Old Oct 4, 2008 | 11:00 AM
terrycs's Avatar
Attachment 96538
First, did your car originally come with one? Does your car have push button ignition? If so, you can have up to 4 I-keys programmed to your car. The dealer will need all I-keys and your car at the same time to do it.
Old Oct 4, 2008 | 11:10 AM
eagleee's Avatar
Thanks for the info. The seller name is mag7437. Car came with the I-key. Just bought an extra one just in case I lose one.
How much does the dealership charge to program the I-key?
Old Oct 5, 2008 | 02:50 AM
dougbert's Avatar
How much for programming the I-key?
I've been quoted $50 for the programming from my local Nissan dealer.
Old Oct 5, 2008 | 03:18 AM
yeah, anywhere between $50 and $100.^
Old Oct 5, 2008 | 03:29 AM
eagleee's Avatar
I just got it done earlier today for $45.
Old Oct 5, 2008 | 12:14 PM
eric300zx's Avatar
Good for you! How is the new key working for you?
Also, how much was it you payed for in Ebay?
I just it done earlier today for $45.
Old Oct 5, 2008 | 12:20 PM
eagleee's Avatar
$6 for the I-key + $5 for shipping..$11
What a deal huh..
Old Oct 5, 2008 | 06:20 PM
RADIOGUY21's Avatar
this i-key you purchased off ebay, does it include the actual key that goes inside the I-key? And if so, was it blank, meaning it just needed to be cut? I have seen some i-keys on ebay but some of them are used, which most likely means the actual key is cut for another car. Thanks.
Old Oct 5, 2008 | 06:32 PM
mIKE's Avatar
all keys must be together for programming.
Old Oct 5, 2008 | 07:13 PM
eric300zx's Avatar
No way!
Wow, I could not find anything cheaper than $40, the seller you mentioned must have had only one. I don't see his listing...
Congrats!
What a deal huh..
Old Oct 5, 2008 | 09:26 PM
eagleee's Avatar
It was a used i-key and the mechanical key that came with it was already cut.
Old Oct 5, 2008 | 09:28 PM
eagleee's Avatar
What do you mean by all the keys must be together? So its not possible to program the i-key without the mechanical key? Does the mechanical have to match?
