Need Help please
Old Oct 7, 2008 | 08:03 PM
ttrank's Avatar
Grocery getter
The oem battery can die with no warning. It happened to me too and I was shocked. Most batteries will start to die off and you have some warning. Not always the case. I bet it's the battery.
Old Oct 7, 2008 | 09:55 PM
playboyHD's Avatar
well thanks for all the help, i got a new battery, had them<strauss auto> charged it and i installed it. still doing the same thing. a stranger gave me jump ..nothing .. so it's not the battery .. any suggestions.? thanks in advance
Old Oct 7, 2008 | 10:33 PM
jimrockford's Avatar
A bad starter is my best guess if the new battery didn't fix it.
Old Oct 8, 2008 | 10:09 AM
playboyHD's Avatar
yea I figured the same, so i have to tow it back to the dealer. Thanks
Old Oct 8, 2008 | 11:26 PM
Good luck. Let us know if that turns out to be the cause.
Old Oct 8, 2008 | 11:40 PM
Kazaam's Avatar
update??
Old Oct 9, 2008 | 10:37 AM
playboyHD's Avatar
Originally Posted by Kazaam35x
update??
nothing yet it's at the dealer and they are closed today so hopefully i get it back tomorrow.
thanks
Old Oct 9, 2008 | 10:44 AM
playboyHD's Avatar
just recieved a call from the mechanic and i was told that it's the alarm system that's causing the issue and he is not certain if he can fix that. so i have to hear what the dealer says tomorrow.. thanks guys
has anyone had this problem before?
Old Oct 9, 2008 | 12:48 PM
ttrank's Avatar
Grocery getter
Aftermarket alarm or oem? I didn't think the oem had a starter kill, just the immobilizer.
Old Oct 9, 2008 | 01:11 PM
playboyHD's Avatar
it's OEM .. if there is a way to fix this, please let me know so i can tell the mechanic something so i can get my car back sooner.
thanks
Old Oct 9, 2008 | 01:15 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by Jeff92se
the battery could be dead. Try a jump. Or since you mention the alarm light, the ign disable could be on still. Maybe a low battery would do that.
= alarm = possible problem with the key transponder and ecu not reconizing the key.
Won't know until you put a good battery in it first to eliminate that possibility.
Old Oct 9, 2008 | 01:22 PM
playboyHD's Avatar
i have 3 keys none works.. it that still possible? /\
Old Oct 9, 2008 | 01:23 PM
Jeff92se's Avatar
Red Card Crew
If the problem is with the ECU it will be
Old Oct 9, 2008 | 01:30 PM
playboyHD's Avatar
Thanks so im guessing that the dealer(private) can fix this
Old Oct 9, 2008 | 01:34 PM
  #30
Jeff92se's Avatar
Red Card Crew
Not sure what else to advise. I would have at the very least put jumper cables on it and tried to start the car YESTERDAY. If no, then off to the dealer you go. Unless the mechanic knows what to do. (which I'm doubting at this point)
