???toe/camber Arms On Ebay???
Old Nov 18, 2008 | 10:34 PM
AARONHL's Avatar
How are the rear toe/camber arms on eBay as far as quality, fitment, correcting, etc.?
http://cgi.ebay.com/ebaymotors/Nissa...3A1|240%3A1318
http://cgi.ebay.com/ebaymotors/NISSA...3A1|240%3A1318
http://cgi.ebay.com/ebaymotors/SPC-E...3A1|240%3A1318
Thanks,
Aaron
Old Nov 18, 2008 | 11:04 PM
NathanJax's Avatar
..... I WIN .....
Not sure about some no name brand stuff when u can get quality stuff in the for sale section here at almost the same price.
I have a SPC rear camber kit for sale here... https://g35driver.com/forums/suspens...mber-arms.html
Old Nov 18, 2008 | 11:12 PM
AARONHL's Avatar
The camber arms would be all I need to get my rear camber within specification, correct?
Old Nov 19, 2008 | 12:06 AM
NathanJax's Avatar
..... I WIN .....
From my understanding, all you need is the camber arms in the rear. Depending on your drop, if you get the bolts, it allows you to change the camber even more.
For example, and I'm just pulling these numbers out of my ****...
if your camber is -2, you can fix that with just the arms...
if your cambers is -3, the arms will give you a fix up to -2, and the bolts give you the extra -1 you need.
I'm no specialist, so maybe someone else will chime in, but I was thinking of going a little lower, and that would have given me a slight camber issue. I was told I could just use these and be fine, and I didn't need the bolts.
I googled it, and...
For the arms it said, "This is the perfect kit for the lowered Z. Provides plenty of adjustment for camber and comes with a larger offset toe cam to bring the toe angle back into range."
For the bolts it said, "These cams replace the OE camber and toe adjustment cams and provide additional camber & toe changes."
Old Nov 19, 2008 | 12:22 AM
AARONHL's Avatar
GREAT EXPLANATION! I'm at -2 right now as the alignment specialist said, so the arms will help me out a bit. I'll be looking for some of these soon, possibly yours.
Thanks,
Aaron
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
nanobotking
Oct 8, 2015 08:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
