question about air filter..
Old Dec 8, 2008 | 03:37 AM
Cali_G35's Avatar
Just replaced my air filter and i have a question.. Does the rubber hose from the engine go over the plastic teeth of the piece pictured below?
Old Dec 8, 2008 | 11:58 AM
Jeff92se's Avatar
Red Card Crew
No. The picture is correct.
Old Dec 8, 2008 | 09:57 PM
OCG35's Avatar
the "rubber hose" you reference must be the intake tube?... if so, that slides over the collar on the other end of the item in the pic which is the MAF (mass air flow sensor) housing (the end facing you in to pic bolts to the air box) - the edge of the intake tube will butt up against the few raised portions (I presume what you referred to as teeth)... tighten down the hose clamp and you're done.
Old Dec 8, 2008 | 09:59 PM
05DGx's Avatar
^ couldn't have said it better myself
Old Dec 8, 2008 | 10:10 PM
Cali_G35's Avatar
thanks guys... Just wanted to make sure if i did everything right..
(my digression): I just love my g35.. It exceeds all my reservations about infiniti vehicles. Having to own pretty much hondas and toyotas, my g35 simply truncates my previous cars, including my acura cl type s and lexus sc400.
Old Dec 8, 2008 | 11:29 PM
Kimbo80's Avatar
If you are not sure, I highly recommend watching this video. These guys took the time to show you step by step in their videos.
http://www.infinitihelp.com/diy/gsed...dure_video.htm
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
