Top $40 and UNDER mods
you might want to spend a few seconds and look at the sticky threads or FAQ section. you will find it or you can use the SEARCH option!
i will make it easy for you.
https://g35driver.com/forums/g35-sed...on-thread.html
Pics? I have an entire thread
http://www.nfspmotorsports.com/forum...php?topic=51.0
Here's a current (albeit crappy) pic:
If you'll click the link to my car (under my username) there are more pics, and links to tons of pics on NFSPMotorsports.
http://www.nfspmotorsports.com/forum...php?topic=51.0Here's a current (albeit crappy) pic:
27. Blue Batmans Overlays - Each piece or set is usually under 40 bucks.
28. Adding aux input to Bose radio. ($5.98)+tax
29. VDC disable/Yaw sensor switch[/quote]
30. Home Depot Lip Less than $25
31. Refinish your stock wheels, maybe $40 -$50
32. DIY 6MT Clutch Mod ($5)
33. ebay Engine dampener ($39.99 shipped)
(Stillen Replica, pretty much EXACTLY the same as Stillens', minus the name.)[/QUOTE]
34. Coolant Bypass mod (just need a small inline valve)
Official Sponsor of the Florida G35 Club
1. RHD Battery Cover
2. JDM clear corners
3. led lights
4. debadged
5. painted oem grill
6. polished bolts around plenum
7. K&N drop in filter
8. Painted oem headlights
9. Painted oem engine cover
10. Nismo radiator cap
11. Nismo oil filler cap
12 Painted calipers
13. Z-tube
14. DIY Oil Catch Can
15. 2 degrees andvanced ingition timing
16. Drop using Z springs
17. Blue Batmobile Overlays - .
18. KP Tech modules
19. Home Depot Lip Less than $25
20. Ace hardware airbox mod - https://g35driver.com/forums/engine-...-anti-56k.html
21. DIY grounding kit
3. led lights
4. debadged
12 Painted calipers
13. Z-tube
18. KP Tech modules
.Bat™
wow thats weird I was thinking about #20 last night and though it might be something amazing and new, and now I see it here and I am kinda sad lol. But oh well.
Bump on "what is the 6 buck Aux Bose mod"
My shift boots are $40 and under shipped
Check out this thread for more info
https://g35driver.com/forums/accesso...available.html
