Waxing wheels?
Old Jun 7, 2004 | 09:40 AM
Gman_Zman's Avatar
Waxing wheels?
I read in the owners manual that the wheels should be waxed because of road salt. I have never done this, and I was wondering if i should start. Thanks in advance.
04 G35x--Desert Platinum--Premium--Willow
Old Jun 7, 2004 | 10:15 AM
NeedSpeed's Avatar
Re: Waxing wheels?
Waxing the wheels is a very good idea, it also helps with brake dust. You wouldnt eliminate the brake dust but it will be alot easier to remove it when you wash the car. I always wax my wheels , more often than i do the body, but im neurotic
Old Jun 7, 2004 | 10:25 AM
Payam81's Avatar
Re: Waxing wheels?
I have to agree! Waxing will protect your wheels. It's real easy, just apply wax as you would to your car, not much different.
Old Jun 7, 2004 | 11:59 AM
afr0puff's Avatar
Supa Dupa Moderator
Re: Waxing wheels?
LOL! i don't know about easy. It's a pain in the **** if you ask me. I use zaino and usually just take my wheels off twice a year and apply 3 coats. Then I don't have to worry about them again.
http://www.anythingbox.net
Old Jun 7, 2004 | 12:04 PM
bsgoren's Avatar
Re: Waxing wheels?
Not only do I wax my wheels, but I also wax all lights (headlights, tailights, etc.), all painted surfaces (including moldings) and chrome tailpipe tips and moldings...why not?? The wax definitely protects all the surfaces and keep them shiny.
I noticed that most car wash/detail places typically just wax the regular painted surfaces (probably to save time and $$). If I don't feel like waxing my car, I'll have my local car wash/detail place do it (with my wax), and I'll just ask them to wax 'everything' with their orbital waxer. To me, it's worth the $25 plus $4 tip to watch them do it! ;-)
2004.5 Infiniti G35 Sedan 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels
(basically Sport Package w/o stiffer suspension), Darkest Tint (this is FL afterall), Z Tube, K&N Filter
Old Jun 7, 2004 | 03:12 PM
KingoftheRoad1's Avatar
Re: Waxing wheels?
If you are going to spend the time waxing your wheels, then you should try this product. Go to www.corrionx.com and look for RejeX. This product is not a wax and last a lot longer than wax. You can also use it to wax your car!!! I have been using it for some time ever since I read it in Car & Driver(not an ad). It is easier to apply and lasts a lot longer than wax. Check it out!
2004 G35X
Old Jun 7, 2004 | 03:57 PM
rajanb's Avatar
Re: Waxing wheels?
I wax the wheels - just the outside areaa though. I use a product called RejeX (similar to wax) and it makes a big difference in getting the brake dust off.
G35S AT / Ivory Pearl and Black
Old Jun 7, 2004 | 10:02 PM
Payam81's Avatar
Re: Waxing wheels?
you probably wax em inside out?! ) I only suffice to the exterior. It takes a good 30 minutes for all 4 but I only apply it 4-5 times a year so it's ok.
One question though, do you have to balance/align them every time you take em off?
Old Jun 8, 2004 | 08:43 AM
Re: Waxing wheels?
81, no you don't have to balance and align them when you remove the wheels. However, when you rotate the tires, you may have to balance them again because the rear tires sometimes may not be balanced correctly due to the wear, and you won't feel it until you put them in the front. As for the front wheel drive cars, the wear mainly come from the front tires.
2004 G35X
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
skippyG
Jan 25, 2016 01:18 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Nog89
Jul 21, 2015 03:02 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
