Air intake?
Old Jan 1, 2009 | 09:47 PM
koG35ko's Avatar
Air intake?
Hi guys,
I have a 06 G35 Sedan.
Thinking about getting Injen air intake.
Anybody have suggestions or recommendations?
How about Stillen?
Thanks, appreciate your comments and help.
Old Jan 1, 2009 | 09:54 PM
5150DS's Avatar
First you need to make sure you post in the correct section to get responses. There is a sub forum specifically for intake and other engine mods. Second there is a FAQ thread, on the top of the 03-06 sedan sub form, that addresses this issue. Last you only get a few hp (mostly for noise) from an intake so I would try to meet up with someone with the intake you are looking at so you can listen to their setup.
I am letting you know the above info so you are not flamed on this forum. Don't be surprised if this thread is locked and deleted.
Old Jan 1, 2009 | 10:12 PM
G35m@'s Avatar
SEARCH is your friend -
I'm partial to my Z tube and pop charger -
Old Jan 1, 2009 | 10:31 PM
Texasscout's Avatar
I have tried several, I have the NISMO Cold Air Intake (long runner) now, sounds unreal. However, none of them really added any power. The cheapest and best route for you is a Z-tube (air tube from a 350Z) and a good K&N or Fram Air Hog filter for the OEM box. The Ztube will give you that sound you crave (OEM tube has a sound dampener) and the High Flow Air Filter will give you a little more HP. You can get the whole thing done for less than $150.
Old Jan 2, 2009 | 01:56 AM
AceG35X's Avatar
Honestly the intake does more for you car as far as noise rather then HP, my fujita intake sounds beastly.. but it only gets loud after 4000 rpms.. so u can cruise and the car will still be as quiet as stock.. also there is a nice whistling sound for a split second when you tap the gas.. are you in the Jersey area?
Old Jan 2, 2009 | 07:57 AM
jimmykce1's Avatar
I had a Stillen CAi on my car for a year than switch back to stock airbox. I noticed when I switched back I gained a little more torque back that the Stillen lost. Now I am awaiting a 2007 rev-up OEm air box.
Old Jan 3, 2009 | 12:04 PM
Swivel's Avatar
Moderator
Good advice, you can go with K&N drop-in (I have this now) or Amsoil dry filter (switching to in future) which does not require oiling like the K&N.
Old Jan 3, 2009 | 02:58 PM
koG35ko's Avatar
guys,
thanks for your valuable info, i really appreciate it!
ONE more question, can i get the Z tube at any Nissan dealer? any suggestions where i can get it at a good price?
I am in Los Angeles. just got my G35 2 months ago.
slowly moding it
for interior i have installed Pioneer Avic F90bt, LOVE IT.
Hope to have SSR LM9 (19") on the ride by March, while wife will be in Taiwan.
Old Jan 3, 2009 | 03:58 PM
PAIXAO's Avatar
Check www.my350z.com or check the classifieds/marketplace here. There are lots to be found cheap.
Old Jan 3, 2009 | 09:17 PM
phrocker's Avatar
Originally Posted by koG35ko
guys,
slowly moding it
If you aren't successful checking the classified as TwilightBlue mentioned, Stillen sells a z-tube for 58 bucks.
Old Jan 4, 2009 | 12:05 AM
Tollboothwilley's Avatar
People that go to aftermarket intakes generally end up with a loss in torque. This is due to heat soak, which is prevalent in the engine bay. Long tube intakes do not work well with the VQ35DE. If you are going to go aftermarket (and I HIGHLY recommend it) you should think about using some heat wrap to isolate the intake temps. The jwt pop charger is awesome, but the heat shield doesn't really keep the temps down.
Old Jan 4, 2009 | 02:01 AM
5150DS's Avatar
R2C is another choice. I don't know if anyone has tried it yet. Similar to the popcharger, but the heat shield looks like it has a little more coverage. Here it is available for $140. https://www.upscaleautomotive.com/p-...initi-g35.aspx
Old Jan 4, 2009 | 12:33 PM
Hotdawwgman's Avatar
i am rockin the Z-tube and the K&N Filter... and i love them, perfect sound and power response
Old Jan 5, 2009 | 12:53 AM
indyjrt's Avatar
I did this mod yesterday to my wife's "G".
She doesn't know! muah!! I told her I only cleaned the air filter!
Old Jan 5, 2009 | 12:54 AM
jutn35's Avatar
G35 Coupe
Gettin my Ztube in the mail soon !! yay OEM !
