Need help with headlights
Old Jan 3, 2009 | 09:52 PM
xBOUNCERx's Avatar
I have a stock '05 G35 sedan with hid. I recently replaced bulbs and it seems that the lights point lower than before. I can't find the screws which move lights up and down. I had a Q45 before and it was right under the hood (one screw on each side for hid's and one for high beams). But on this car I have absolutely no idea how to raise the lights. I searched but couldn't find any postings. Can someone please let me know where those screws are, if the car has them, and if it doesn't, how can I adjust heights of my lights
Old Jan 3, 2009 | 10:50 PM
6MTFTW's Avatar
Straight from the FSM:
PREPARATION BEFORE ADJUSTING
For Details, Refer to the Regulations in Your Own Country.
Before performing aiming adjustment, check the following.
1. Keep all tires inflated to correct pressures.
2. Place vehicle on flat surface.
3. Set that there is no-load in vehicle other than the driver (or equivalent weight placed in driver's position).
Coolant, engine oil filled up to correct level and full fuel tank.
LOW BEAM AND HIGH BEAM
1. Turn headlamp low beam ON.
2. Use adjusting screws to perform aiming adjustment.
The height adjustment is the lower adjuster screw on the back of the housing.
-Jerome
Old Jan 4, 2009 | 01:32 AM
xBOUNCERx's Avatar
So there's 1 screw for high beams and one screw for low beams on each side?
Old Jan 4, 2009 | 10:27 AM
Dan in St Louis's Avatar
See attachments
Attached Thumbnails Need help with headlights-2005headlights01.png   Need help with headlights-2005headlights02.png
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
