Why is my car so slow?
Old Jan 11, 2009 | 12:52 PM
GT-ER's Avatar
Originally Posted by TwilightBlue
Using the oldest available readings from Carolina PR this is what I came up with:
At 1pm yesterday:
Altitude is 13ft
Air Temp was 82.9 degrees f
Barometric Pressure was 30.07
Dew Point was 69.1
Your Density Altitude is 1686 feet...
Meaning, the conditions were similar to those at 1686 feet. Not that big of a difference from seal level BTW.
It was at 9pm give or take. Where do you get that info?
Old Jan 11, 2009 | 12:55 PM
GT-ER's Avatar
Originally Posted by OCG35
I know its hard to accept (especially for some out here) – but launch off idle *for now*
Brake torque cuts power… I’ve been saying it forever, its finally been proven. I used Cipher at last track event and data-logged particulars that Up-Rev requested to diagnose issue… after sending the spreadsheet to them, they confirmed that the throttle is cut for a moment when the ECU recognizes the accelerator and brake are depressed at same time.
I’ve dealt with this for a looonnng time and determined 2-3 years ago that my 60; is actually better when launching off idle (even at 650-700rmp) than power-braking to 2-2.5K
The reason I said *for now* in first sentence is that Up-Rev is working on a solution… that was the whole reason I asked them to look at this issue… so we (AT) might be in business in the near future!
Well you know what...on one of the launches I noticed that from 1500rpm to 3000rpm or so that car reved up sloooooowwww...to the point that I wondered if something happened and then it immediately snapped be back and kept going great. By low I mean regular driving slow...that run netted me a 15.2.
Odd thing is that if I power brake on the street I can do a burn out...on the track was a different question. Maybe it's because I powerbrake at the last second on the track while in the street I powerbrake and after a moment that car starts to spin it's tires. It feels like it has turbo lag.
Old Jan 11, 2009 | 12:57 PM
OCG35's Avatar
you can burn out all day long... it doesn’t mean your 60' times are good... the car will eventually get up & go... on the street you wont notice that it takes a little longer to actually go. at the track .1-.2 seconds is very noticeable... on the street, you probably won’t even realize it.
Old Jan 11, 2009 | 01:00 PM
PAIXAO's Avatar
At 10pm (no info avail for 9pm, only 8pm and 10pm. I chose 10pm)
Altitude 13ft
Air Temp 77 degrees f
Barometric Pressure 30.12
Dew Point 66 degrees f
Density Altitude = 1248
Weather conditions are available from the National Weather Service. Density Altitude needs to be calculated using the above info.
Old Jan 11, 2009 | 01:03 PM
GT-ER's Avatar
Thought so as well. Interesting.
Old Jan 11, 2009 | 01:17 PM
GT-ER's Avatar
Altitude 13ft
Using that info my car would run about 14.8@93mph at 0 DA...correct?
Old Jan 11, 2009 | 01:47 PM
PAIXAO's Avatar
That is what I calculated also
Old Jan 11, 2009 | 02:08 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Ok mostly good answers, you should be able to cut that down to 14.3-14.5 easily. Keep trying, oh and lose 15 pounds and the spare tire
Old Jan 11, 2009 | 02:32 PM
Mustang5L5's Avatar
Originally Posted by MyocyteX
Not a single question answered.....
Yes he did. Post #3 in bold
Old Jan 11, 2009 | 03:04 PM
Jeff92se's Avatar
Red Card Crew
Go UpRev!
Old Jan 11, 2009 | 04:03 PM
OCG35's Avatar
Originally Posted by Jeff92se
Go UpRev!
Old Jan 11, 2009 | 04:10 PM
canucklehead's Avatar
get your car tuned/or diagnostic check. something must be wrong to see 15+ consistently, unless you had a bad run. ~1600' is not enough altitude to run that slow.
lots of good suggestions in the other replies, but to gain .5-.7 seconds you need some serious improvements, or determine what is wrong with your ride.
just for reference, i ran my car once at the 1/4 mile track nearby (~500') on a hot summer night and saw 14.3 @ 98+, with a 2.1 60'. i'm essentially stock.
Old Jan 11, 2009 | 05:44 PM
Wannabe6MT's Avatar
-MN G Crew-
See...that just makes me sad...LOL.
My track is in Carolina, PR. The Name is Carolina Speedway and the date was 01/10/09. I don't know how to get the track info though so I don't know the altitude and what not. PR is normally very humid as it is a tropical island but yesterday wasn't too bad.
As for the wheels...they are stock.
My previous car was a 2000 Pontiac Grand Prix GTP that bone stock ran exactly the same 15.0@92mph. The only difference is that with less than $1000 I ran 13.4@102mph...LOL. After that I added a nice turbo ( everything else stock ) and ran 12.6@111mph. Forced induction FTW!
lol i ran a 15.6@87 in my 03 Trailblazer. That was the only time i had been to the track. After that, i declared the G has to go faster than 15.0. You should to
Old Jan 11, 2009 | 06:01 PM
DaveB's Avatar
Did you manually shift the 2-3 and hold 3rd gear or did you let it shift into 4th?
Old Jan 11, 2009 | 10:54 PM
  #30
GT-ER's Avatar
I shifted to 4th but at the end of the track holding it or shifting would probably have barely done a difference. My launch is the what would make a world of a difference....If I could only get it to launch well.
