Kinda worried. Another ABS/VDC Off/Slip lights on thread...
Old Jan 28, 2009 | 01:52 AM
Lucky-G's Avatar
I knows I miss the LSD in my 240. I may buy one in a year or so when I have some real power to lay down.
Old Jan 28, 2009 | 01:55 AM
Wannabe6MT's Avatar
-MN G Crew-
lol Its fun pulling 1 wheel wonders though
Old Jan 28, 2009 | 01:57 AM
Lucky-G's Avatar
def is not!
My 240 was the most fun thing I've EVER driven as far as handling wise. That thing cornered like a CHAMP. Getting slideways was still hard though because it was so low on power. Hell the G's 1-wheel-wonder gets there easier, but it's far harder to hold it there.
Old Jan 28, 2009 | 11:15 AM
RADIOGUY21's Avatar
well i think your obvious problem is your tires. But if all those lights went ON and stayed lit that just means the system went into fail safe mode and should reset to normal at the next engine restart.
Old Jan 28, 2009 | 12:24 PM
AARONHL's Avatar
Then after your alignment the lights will turn off.
Old Jan 28, 2009 | 01:44 PM
Lucky-G's Avatar
Heading out to my car in a few mins. Will update this later with results
Old Jan 28, 2009 | 02:37 PM
ttrank's Avatar
Grocery getter
Yeah it can be normal. After drifting around they come on for me.
Old Jan 29, 2009 | 01:52 AM
Lucky-G's Avatar
Everything's back to normal. Was actually really weird. It didn't go off until I knocked a TON of snow out of the wheel wells. I had to use my ice scraper lol. The wheel wells were so packed it was coming in contact with the tires, so I'm wondering if maybe that had something to do with it?
Old Jan 29, 2009 | 11:19 AM
racefan318's Avatar
What's up with this "fail safe mode"? Our 03 G has had 2 occurances of all 3 of the lights coming on at teh same time for no reason. There was no rain, snow, ice, anything on the ground, but it was about 25F each time...
Old Jan 29, 2009 | 12:34 PM
RADIOGUY21's Avatar
iirc VDC is completely disabled in this mode. It is to protect the VDC system and the car if there is a problem. The system will go into this mode when theres a bad sensor (which may be your case), or when VDC is running for a prolonged period of time such as trying to get out of deep snow with VDC turned on and sometimes even off. Usually it resets itself after the next restart but if all the lights are still on then it should be serviced by the dealer.
Old Jan 29, 2009 | 01:23 PM
racefan318's Avatar
Both times, a quick off-on has reset the lights... What's weird to me is that the only 2 times it has happened, were on the 2 coldest days of the year so far.
Old Jan 30, 2009 | 07:27 AM
jmcohen23's Avatar
next time, trying pressing the "snow" button (if equipped). it should be in front of your right knee when sitting in the driver's seat.
Old Jan 30, 2009 | 06:48 PM
AceG35X's Avatar
Those lights came on when i was doing donuts in a parking lot.. turned off vdc cause like others have said... the power gets cut off and u go nowhere.. but all i did was put my car into park and it went off a few seconds later.. drove fine no problems..
Old Jan 30, 2009 | 11:10 PM
Lucky-G's Avatar
Oh....he's serious......only the X comes with a "snow" button dudeskee! If I had a snow button, I would've had all wheel drive, and I probably wouldn't have gotten stuck lol. and welcome to Driver though!!!
Old Feb 1, 2009 | 12:04 AM
  #30
G-ealousy's Avatar
^^ lol ^^
