Will 08 m45 wheels fit an 04 g35x ?
Old Feb 9, 2009 | 04:41 PM
deevel79's Avatar
Originally Posted by LowBallJ
Yeah those look nice and the price is sweet. I'm a little gun shy since I'm a new G owner and was more of a fan of M45 19s https://g35driver.com/forums/wheels-...ml#post2663974
Although the 19's would look nice, you're going to sacrifice your ride quality. ESPECIALLY in NYC with all the potholes, etc. Me personally, i wouldnt go any bigger than 18's living here in the city.
Old Feb 9, 2009 | 05:49 PM
FenixL1P's Avatar
i have a set of pre-08 m35/m45 19" sport rims. they don't have that flared rib on the spokes. i had to buy spacers to make them fit. if pre-08 and 08 are the same offset then you'll need a minimum spacer thickness of 5mm to clear, but i recommend 10mm. Go 15mm if you really want a flush fit. the cons to this mod was the requirement for longer studs so you don't chance loosing your wheels to broken studs...
Old Feb 9, 2009 | 08:11 PM
LowBallJ's Avatar
I'm not in any hurry to get rims but the summer is coming and the original tires have 30k on em. If I'm going to get new tires and brakes, might as well go bigger and better
Old Feb 9, 2009 | 09:03 PM
Mustang5L5's Avatar
Originally Posted by 04G35Sedan
But just as a rule of thumb, with an AWD vehicle, we cannot run staggered wheels, which means they need to be even width all the way around.
No, not even width. Even Diameter
The car doesn't care how wide the wheel is. All it cares is that both the front and rear wheels spin at the same rate.
Old Feb 10, 2009 | 02:24 PM
04G35Sedan's Avatar
That's what I meant innately, just couldn't spit it out right.
Old Feb 10, 2009 | 02:32 PM
ttrank's Avatar
Grocery getter
I like the older M wheels a lot more than those.
Cajuncowboy
Jun 21, 2021 09:47 AM
reavensf
Sep 17, 2015 11:30 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
