I know the coupe and sedan have different offsets but will these rims fit the sedan?
20 x 8.5 FRONT with +40 offset (+20 is also available)
20 x 10 REAR with +35 offset (+25 is also available)
Sedan is lowered in rear on 350z revised springs.
your good to go, but 10" in the back and depending on what width of the tire, you might need to roll your rear fenders
now I'm even more confused. how can you run a 19x10 in the back with a +20 offset?? thats coupe fitment.
i have a camber kit so adding neg camber isnt a problem.
what size tires should i run?
Do you want that look with the super stretched tires and the wheels that stick out past the fenders? If so you can run that offeset.
If you run the 1st offset you asked about and roll your rear fenders you can run more standard size tires (245 front and 275 rear) with a normal amount of camber.
thanks ttrank for clearing that up. That stretched tire, way negative camber, looks hot, but it isnt for me. I dont want to worry about popping a tire or curbing the rims every second.
I just want something to sit flush against fender. I will roll the fender if a need to
I'm looking at running 19x10 +32 at the rear. Already lowered on z suspension and rear fenders have been rolled and -1.5 camber. Would be interested to see pics of yours before I take the plunge
what else is important.. what kinda wheels?!Originally Posted by CLyons0203
I know the coupe and sedan have different offsets but will these rims fit the sedan?20 x 8.5 FRONT with +40 offset (+20 is also available)
+20? on the front of a sedan. 8.5" wide. Wont that stick out past the fender?
The rims I am looking at are TWS Thurxtons. They are not a super high quality rim like Volk or Work, but I think they are around the same quality as a Sevas rim.
about to purchase these. I have decided to go with
in the back - 20x10 +35 275/35/20
in the front - 20x8.5 +20 245/35/20 or should I go with the +40 offset??
tires are going to be falken fk 452
