AC problem blowing hot air HELP!!
Old Jun 13, 2011 | 11:34 PM
kgilmore11's Avatar
Alright guys, I've got a '03 G sedan and anything below 90 it'll blow cold... Any options??
Old Dec 11, 2012 | 01:35 PM
iamchris's Avatar
Originally Posted by _G35_
Next to the black hose, it is right beside the center console. If you look at the panel you will see(I think its 4) lines and a hard, shiny plastic piece and the hose and clip should go right behind there.
bumping an old *** thread hopefully i get a response here.
are you talking about this piece?
Old May 25, 2016 | 10:55 PM
Bufadora365's Avatar
AC blowing hot air with compressor in gagging
Hi ac blowing hot air because the compressor wasn't in gagging the Mecanico give voltage with a manual switch and I had cold air. Now with the compressor on ac is blowing hot air help me please.
Old May 11, 2018 | 10:10 PM
Coed44's Avatar
New compressor last year
&it was freezing cold... This year its all hot air
Old May 11, 2018 | 10:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Leaked out all your refrigerant.
Old May 12, 2018 | 11:40 AM
Coed44's Avatar
So I cud possibly need sum refrigerant
Old May 12, 2018 | 12:17 PM
FreshLikeAG's Avatar
If you lost it that quickly I suspect there's a leak somewhere that needs to be fixed. Don't need that **** leaking into the air we breath
Old May 12, 2018 | 06:17 PM
cleric670's Avatar
BANNED!!!
Take it down to an auto AC shop and have them pump it up with nitrogen and find the leak, fix the leak, recharge the system. If your system is completely empty DO NOT just use bottles of AC PRO or other recharge cans, you get a really bad mix of refrigerant and oil and most of them have stopleak which is really bad for the rest of the system. Using that crap in large volumes is a guaranteed way to cook your compressor within a few years.
If this is just a disposable vehicle that you're getting rid of soon then I guess it wouldn't matter and you can limp through a couple years though.
Nothing wrong with using AC PRO to top a system off yearly if you're only down a few psi.
Old May 12, 2018 | 08:10 PM
Coed44's Avatar
Thanx... Im gonna get it chkd out... But I can't really tell if the AC is coming on... It sez it on the dash but I do not hear the engine go down or any change 2 the engine when I cut the AC on. How can I tell if it is coming on besides the dash?
Old May 12, 2018 | 09:55 PM
cleric670's Avatar
BANNED!!!
Best way is to open the hood and have someone else hit the AC button while you stand at the engine and listen for the audible CLICK sound from the compressor cycling on and off.
Old May 13, 2018 | 11:52 AM
Coed44's Avatar
Thanx...
So if there isn't an audible click that means it's not coming on & compressor is dead?
Old May 13, 2018 | 12:06 PM
cleric670's Avatar
BANNED!!!
It just means the compressor is not cycling on, some vehicles the low pressure switch will 100% prevent engagement, some vehicles it will engage and immediately disengage. You can unplug the compressor harness and (carefully) test for voltage to see if it's even getting power.
There is also an AC relay inside the IPDM, if you remove the cover and put your finger on it you should feel the vibration from the contact opening and closing while someone operates the AC on/off with the engine running. If the contact isn't operating test it to make sure it's not broken.
There is also a master fuse for the AC located in the fusible link directly attached to the battery. You can visibly inspect it, there are viewing windows for the fuses. Also a fuse in the IPDM I believe for the control side.
Old May 13, 2018 | 12:07 PM
cleric670's Avatar
BANNED!!!
On second glance, low pressure should prevent the compressor from turning on AT ALL. You're probably just low on refrigerant and need to get it inspected and fixed.
EDIT: Usually you can tell where it's leaking from because when it leaks out the oil comes out as a VERY fine mist that sticks to the pipes or components so you end up with a compressor line that's completely covered in dirt that sticks to the oil tracks.
Old May 13, 2018 | 01:18 PM
Coed44's Avatar
Thanx again... I appreciate ur time
I'll chk things out but if it seems 2 complicated or ill break sumpn I'll b @ a shop... Lol
Can we sell things on here? I'm new so I have no clue.
champppy
Mar 31, 2020 12:25 PM
Greg Huston
Sep 25, 2016 11:36 PM
baker2795
Sep 2, 2015 06:00 PM
G35CO
Aug 25, 2015 02:00 PM
chinee
Aug 8, 2015 10:11 AM
