suspension help
Old Mar 27, 2009 | 05:27 PM
r1forever80's Avatar
suspension help
hey guys im new here. Ive read the sticky and searched but can find my answer. I got a 04 sedan with 245/35/20 8.5" wide rim up front and 255/35/20 9.5" wide in the back. When i take a turn at high speed the slip light goes on and if i go too fast the abs kicks n i think. If im turning right the left front brake kick in. I took it to an alignment shop and they said the tire combo is throwing the geometry. what do yall suggest to fix this?
Old Mar 27, 2009 | 05:33 PM
Jeff92se's Avatar
Red Card Crew
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/40-20 3.7in 13.7in 27.4in 86.1in 736 0.0%
255/35-20 3.5in 13.5in 27.0in 84.9in 746 -1.4%
Odd, I would have thought that 1.4% would be okay.
Old Mar 27, 2009 | 05:40 PM
well the front is 245/35 not 245/40. Im on stock suspension. I think they told me since the rear tire is a 255/35 it raised the rear of car up. So that the car has more body roll now. They suggested that i use stiffer springs of course that would mean lowered springs. Is this correct?
Old Mar 27, 2009 | 05:45 PM
Jeff92se's Avatar
Red Card Crew
Alignment guy doesn't know
245/35-20 3.4in 13.4in 26.8in 84.0in 754 0.0%
255/35-20 3.5in 13.5in 27.0in 84.9in 746 1.0%
1% even closer
Old Mar 27, 2009 | 05:55 PM
well i say alignment guy but the shop had their nissan tech test drive it. When i swapped to my new wheels i had 245/35 all the way round and since the rear is 9.5" the tire was stretched and it didnt do this. I wanted to have a wider tire in the rear and when i put the 255 on the suspension started to act funny. It doesnt feel as stable around turns and at high speeds.
Old Mar 27, 2009 | 07:04 PM
anybody?
Old Mar 27, 2009 | 09:22 PM
Viscous's Avatar
Is your G AWD? That could explain the issues if it was and you were running staggered with two different tire diameters.
Old Mar 27, 2009 | 10:24 PM
no its only 2wd
Old Mar 29, 2009 | 10:32 PM
anybody have any ideas?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
