How to take off the door panel ?
I bought some pioneer speakers to replace my old cracked bose ones but i think i am super dumb and couldn't figure out how to remove the door panel.
any link or tips please ?
it takes alot of time theres clips on the first panel you encounter just pop those off. then you will have screws/nuts take them off then there is a sticky cover that you will have to pull off. u can do that by sticking a plat screwdriver and running it around then youl have full access
I think he means it takes a lot of time if you take off the panel on the front doors that hold the window motor also. If not, I agree, its about 20 minutes for all 4. There are 3 screws per door, then just pull around the edges to dislodge the clips. After that, you can disconnect the window/door lock controls along with the screws holding on the door handle. Congrats, the door panel is now off and you can install your speakers
itgogitrev
Sep 23, 2015 07:08 PM
