Help with wheels
Old May 5, 2009 | 09:13 PM
zhadow04's Avatar
Help with wheels
Hello,
I'm planning to buy a set of Axis shine wheels in the following weeks and I have a few questions. First I have read threads about offsets and honestly I don't think I will ever learn how to figure it out.
I have an 03 on Hp tokico and Tein S-tech springs. I barely have a gap on my fenders and they are not rolled. Now which offset do you guys recommend that would look good without rubbing? I'm looking at a set on ebay 19*8.5F with 245/35 tires 15mm and 19*9.5r with 275/30 tires 20mm.
Thanks for the help.
Old May 5, 2009 | 09:20 PM
az1anbeethoven's Avatar
I assume that you want "safe" offsets and not have a lot of camber...so the widths of your wheels are fine, the better offsets are +35 front and +40 ~ +45 rear...check out the sedan section, if you are going to get axis, a new model is coming out with a stainless steel lip, you don't want the dull polished lip that axis offers...also, if you are on s-techs, then you will need a rear fender roll for sure...GL
Old May 5, 2009 | 09:58 PM
6spSEDANFTW!'s Avatar
hey zhadow04 are u trying to fit the rims and tires WITHOUT rolling ur fenders or are u willing to roll your fenders?
Old May 5, 2009 | 10:55 PM
4DGS's Avatar
With S tech drop you need to roll the fenders for sure. Even running coupe 18s would be cutting it close. Making them fatter and bigger than coupe 19s is for sure fender rollage.
Will look good though!
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
