so i just installed luminics 2500ks (which i really like)
and i discovered a bulb in the passenger headlight was out and i dont know the replacement for it
Which bulb is this
Thank you!!!
Which bulb is this
Thank you!!!
if i am not mistaken this is the 194 wedge bulb.
If it is try exchanging them with some good LED's
PM Dranom tell him i sent you, hell hook you up with really great LED's
from japan
they will look great with your lumnics
from japan
LEDs will burn out faster in that position...try to find hyper white bulbes or just go to autozone for regular 194 yellow halogen ones. they're like $2
thanks very much ive been checking them out and will probably end up going to autozone tomorrow. does anyone know anything about the install, will i have to remove the entire headlight?
You can access the headlight through the plastic fender cover....just turn the wheel to the inside to give yourself more room. You won't have to remove the headlight if you go about it this way. 15 min and you should be done.
cool, thanks
That's what I did earlier to install those bulbs and i was hoping it'd be that easy!
Quote:
i love them
where did you get yours? my V-led's would go out after maybe 8 months.....after 2 sets I just gave up and left it unlit.......Originally Posted by The next best
ive had my leds for 1 year, no problems what so everi love them
I might get LED's a try again if they can last.
Which bulb is this
Thank you!!!
I have an 06 and i dont have the little light bulb. Is this for 03-05?Originally Posted by turboner
so i just installed luminics 2500ks (which i really like)and i discovered a bulb in the passenger headlight was out and i dont know the replacement for it
Which bulb is this
Thank you!!!
Quote:
It is on the pre 05 models.Originally Posted by Cali_G35
I'm using Vled LED for that light too. Been more than 1.5 years, till good.Originally Posted by G SEDAN
where did you get yours? my V-led's would go out after maybe 8 months.....after 2 sets I just gave up and left it unlit.......I might get LED's a try again if they can last.
For anyone who's wondering or is having trouble accessing the wedge bulbs, the two pics below should help you:
Quote:
thanks this is just what i needed!Originally Posted by lexusk8
For anyone who's wondering or is having trouble accessing the wedge bulbs, the two pics below should help you:Registered User
I have the city light bulb on my 06 sedan and replaced the stock bulb with a PIAA wedge bulb (white) rather than a led bulb cuz it gets hot in there.
BTW be careful of those luminics jdm yellow bulbs. I had a pair of them in my lower grills in Optx housings and these bulbs, h3 bulbs, are rubbish. They have been installed for just over two months and one has died and the other has gone from yellow to dark gold!
I thought the city lights were only for pre 05 models only..Originally Posted by clinthammer
I have the city light bulb on my 06 sedan and replaced the stock bulb with a PIAA wedge bulb (white) rather than a led bulb cuz it gets hot in there.BTW be careful of those luminics jdm yellow bulbs. I had a pair of them in my lower grills in Optx housings and these bulbs, h3 bulbs, are rubbish. They have been installed for just over two months and one has died and the other has gone from yellow to dark gold!
