G35 Sedan Suspension Picture Compilation Thread
#257
considering a Zs suspension drops a sedan an inch, I'd say yes... some people think some of that is due to the added weight of sedan - that might be slightly true - but the majority is the length of the strut and spring...
#258
#261
Camber, no, not imo..unless you want the wheels straight...just get the toe in spec and you'd be okay. Alignment...i would suggest it but not right away...you want to give the springs some time to settle before going in for an alignment.
For that kind of drop, you can also go with Tanabe DF210's.
#262
on
quick questoin
i kinda need to know asap so please anyone help me if you can..
i want to get eibach sway bars and lowering springs 1.1 all around kit. i was priced 750 installed. sway bars front and rear, PE bushings, 1/1 springs.
question tho! do i need the toe in spec^^ or cambers or anything?
thanks.
thanks.
#263
for a 1.1" drop you can probably get away with OEM A-Arms and no toe bolt.
If anything, the camber will be a bit negative - if it's not to your liking you can always get adjustable A-arms later.
#264
on
i was told simliar to that, the front will be fine, but the rear camber will be negative is anything so id have to get like camber bolts for about 55$ and it would fix it?
i just ordered the eibach sway bars PE bushings, and eibach pro kit lowering springs. 750$ installed. decent price? + 80$ for alignment if i want.
pictures will be up in about a week.
#266
you should be fine with Eibach Pro... I was withing spec without front or rear camber arms...
parts are probably around $550 (maybe a little more with the bushings) - so $175-200 for install isn't bad..
You shouldn't have to pay $80 for alignment since there will be no camber adjustment - half that maybe for a basic alignment (40-50)... you might want to wait a month or two (depending on how much you drive) let springs settle before aligning...
#268
