G35 Sedan Suspension Picture Compilation Thread
Old Feb 15, 2010 | 10:31 AM
  #271
brandon1978's Avatar
Originally Posted by olopez
Does anyone know if a 03-05 OEM 350z suspension would fit an 06 G35 sedan? If so, would it give me drop over the OEM g35 non sport suspension?
Yes it will fit, and it has the same spring rates as the sport package. It will drop about 1" all around. Because there is already less of a gap in the rear between the fender and the tire, many people think it looks better to use 350z springs in the front and G35 Coupe springs in the rear.
Old Feb 22, 2010 | 05:04 PM
  #272
geesahtee5's Avatar
can someone answer this real quick.. its been covered many times, i know but..
springs for the coupe with drop a sedan, how much more? .5" right?
Old Feb 22, 2010 | 05:14 PM
  #273
4DGS's Avatar
^Yes .5" from a coupe
1" from a Z.
Old Feb 22, 2010 | 06:09 PM
  #274
geesahtee5's Avatar
thanks man^^
Old Feb 22, 2010 | 07:19 PM
  #275
lox1985's Avatar
Alright guys, a little of topic but a result of a drop. What do you use to get your car up and hold it up (not a lift ) I'm dropped on Z suspension and now I can't get the car on the ramps without puting some 2x4 but they snap after everytime i drive over them because they are at an angle and have no support underneath. For me to jack up the car, I have to park on a 2x4 and I don't trust the jack to hold the car while I'm under it and there is not enough room witht the jack anyways. What do you guys think about jack stands? How high can they get the car off the ground?
Old Feb 22, 2010 | 11:40 PM
  #276
SN00P's Avatar
CLUB MODERATOR
i have a quick question my friend has a o6 350z with tein springs he wants to sell me the springs and shocks for $100 bucks they only have like 2k miles on them as well ... should i do it ?? cause i no it will lower my car more cause they are z spring ... what should i do ??
Old Feb 22, 2010 | 11:46 PM
  #277
4DGS's Avatar
^take em, might as well. That is the going rate for them and it gives you back up shocks/struts if your sport ones blow.
Do it. It'll drop ya an inch.
Old Feb 23, 2010 | 07:17 AM
  #278
SN00P's Avatar
CLUB MODERATOR
but they are not stock z springs tho they are the tein h techs so it will drop an additional 1in or how will it work ??? thanks
Old Feb 23, 2010 | 09:35 AM
  #279
4DGS's Avatar
Are the 350Z h-techs? Then yes, add 1" to however much they drop the Z.
Old Feb 23, 2010 | 07:52 PM
  #280
SN00P's Avatar
CLUB MODERATOR
yes they are 350z h techs .... for 100 bucks you think i should get them and they come with all the shocks etc .. ??
Old Feb 23, 2010 | 11:08 PM
  #281
4DGS's Avatar
The springs alone are worth about $150 ($250 new)
Old Feb 24, 2010 | 05:38 AM
  #282
SN00P's Avatar
CLUB MODERATOR
ok then im going to pick them up today ..... the only think im worried about is that it is going to be slammed ... and i dont want to start ripping the under carriage of my car out and stuff .. bottom on on speed bumps and etc
Old Feb 24, 2010 | 10:21 AM
  #283
str3zz's Avatar
R u in AZ??
Old Feb 24, 2010 | 01:46 PM
  #284
SN00P's Avatar
CLUB MODERATOR
no im in FL ......
Old Feb 25, 2010 | 05:14 AM
  #285
str3zz's Avatar
Oh lol. I saw the same spring on local ads for same price though that u r from az
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
