View Poll Results: Did this work for you?
YES
100.00%
NO
0%
TEMPORARILY
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
CHMSL on sedan dim/flickering/not working?
Old May 15, 2009 | 03:34 PM
ar9080's Avatar
So I have noticed even some 05-06's with a failing or dead center high-mounted stop light (the LEDs that are on the parcel shelf in the back windshield). My 03 sedan did the same thing, and for a while I found that hitting the back windshield where the light was made it come back on. When my Bose sub crapped out and I replaced it, I disconnected the CHMSL and when I connected it back VOILA! it was fixed! So before you replace the circuit board at the stealership (Sewell has it listed at $146.21) try this.
Remove the plastic honeycomb cover thing where the sub is (I haven't seen what this looks like in a non-Bose car) there are some clips and adhesive so be careful not to break it like i did!
Unplug the wiring harness that goes to the lights and re-secure it firmly
Replace the honeycomb thing and you're done!
NOTE: this does not pertain to the LEDs in the optional spoiler.
Attached Thumbnails CHMSL on sedan dim/flickering/not working?-honeycombcover.jpg   CHMSL on sedan dim/flickering/not working?-chmsl.jpg
Old May 15, 2009 | 07:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
Thanks for the potential DIY. Glad it worked for you.
Old May 15, 2009 | 08:40 PM
pwebb's Avatar
those speaker covers are a biatch. remove rear shelf if you dont want to break anything.
rear seat bottoms, backs, C pillar trims. pull up on the shelf to release the pressure clips, then out. it will get snagged on the seat belts anchors. you dont have to remove those.
haven't tried tapping on the rear glass, i've just assumed replace the 3rd lamp assembly.
joedaddy1
Jul 28, 2015 02:58 PM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
hrdwirk1
Jul 14, 2015 05:46 PM
