Acceleration Lag with 2006 Sedan -automatic
Old Jun 7, 2009 | 05:04 PM
  #31
rbm g35's Avatar
I can fully relate to the lag you are talking about. I have had my g for 5 months. One that i test drove would smoke the tires from a stand still!!!(04 btw). Never tested mine(assumed it would spin) until 2 weeks later and it simply takes off no spinning what so ever And that is with vdc off.Very disappointed.Did more reading and did ecu reset, runs better but still won't spin the tires which may be juvenile to some but after having performance cars all my life(my c5 would burn them up rolling at 30mph auto) it has become an obcession for me.G runs fine otherwise and I've heard its in the ecu which can be tuned out.Anymore ideas?
Old Sep 22, 2010 | 01:09 AM
  #32
ghosthost2's Avatar
I'm a 2006 g35 sedan owner also (eletronics tech) means i know the importance of good grounds. The 06 G35 has 1 factory ground from block to body (not enough) since this has to start and run the whole car. When i bought the car at 25K it ran like crap compared to loaners from dealer. The way to go is use 8GA car audio wire and plated crimps soldered, get as many points from block to body as you can. I have 5 block and 11 body points, my windows and seat motors are very fast and the throttle response is soo good it scares me sometimes, this car is now a porsche G35. I'll do o-60 in 5 sec!! running 93 octane with K and N and grounds no other mods! Do it you'll B happy
Old Sep 22, 2010 | 09:22 AM
  #33
Sacch's Avatar
Are u sure a grounding kit would make the g35 a five second car? lol
Old Sep 22, 2010 | 12:44 PM
  #34
Mustang5L5's Avatar
Lol. Lets not get carried away here.
Old Sep 22, 2010 | 01:08 PM
  #35
COBRA ESQ's Avatar
Originally Posted by ghosthost2
The 06 G35 has 1 factory ground from block to body...... I have 5 block and 11 body points,
Why not add a ground from the battery to the body?
Old Sep 22, 2010 | 01:18 PM
  #36
kyemaul's Avatar
u can get blitz throttle controller look it up!!!
Old Sep 22, 2010 | 05:22 PM
  #37
alexh521's Avatar
Any interest in making me one of those 5 second grounding kits
Old Sep 22, 2010 | 10:35 PM
  #38
ghosthost2's Avatar
I'l take some pictures but not making any cables to sell. If your going to bother you'll need soldering skills and the million strand audio 8GA wire, forgot to mention i soldered the 4GA batt cables and both ends of the main 4 +wires from the fuses and use conductive grease on all screws pre-cleaned with NAPA QD cleaner so if you do all this you can do it. Lets not forget the water injection to get all carbon out of the exhaust system, took me a year over time to get here but it can be done how bad do you want it??????
nickmcc123
Lights
Oct 7, 2017 12:18 AM
TreeFiddy
Aug 10, 2015 06:50 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
