Bottom door lights
Yep, I saw those too. Good to know they work so well, but it's a bit steep in my book, and they're also pretty far down the LED list so maybe when I get to them I won't mind. I think I'm just going to do license bulbs (because I need one) and ambers for my side lights (just got bump clears). Stage 2 might be a set of festoons for the map lights and doors. We'll see after that.
I figured 50W was a typo. That would have burned 2 holes in the car and boosted you a good 5-7 HP. You would have actually seen the light particles coming out the back. Cool!
go through the middle of your car between the seats, you think you getting out the car and going in the backseat isnt obvious
I got those 49.99 white bulbs also, they work very well and are bright as hell. I think the stock ones are the brightest you can get but the 49.99 white bulb is very good. I can see thru my 20 percent tint well.
Dude, it starts with the lic plate lights, then the next thing you know, your like me and ahve dropped a lot of cash on LEDs and there isnt a single bulb left in your car that isnt a LED haha
I did my map box, glove box, under the doors, map lights, rear map lights, trunk, clear corners, lic plate lights, uhh, i think thats every bulb in the car.
Both my gloves, trunk, and doors have the blue LEDs.. everything else is white..
