Does my G have enough power? Can't spin'em!
Old Jun 12, 2009 | 04:02 PM
FoxyG's Avatar
Cool Does my G have enough power? Can't spin'em!
Just got a 2005 G35X, love the car, real quick (past 3500 rpm) but the low end feels weak! Should I be able to spin the wheels at all from a dead stop, straight take off with VDC disabled? Can anyone? Just wondering if I have a power problem.
Remember, the car is stock. No mods, 5 speed automatic, base model sedan, UHP summer tires, but they are crap Primewell P900s (I think I'll beat the hell out of them this summer and get something worth having in October....)
Old Jun 12, 2009 | 04:08 PM
Pmpjuce06's Avatar
its going to be real hard to spin your wheels with the X... if anything you could be able to chirp your tires but certainly nothing substantial. I think its something like the first 20mph of your car is in all wheel drive (im not 100% sure)
Old Jun 12, 2009 | 04:09 PM
NjMatteSedan's Avatar
did you try breaking while you hit the gas and then slowly let go of the break while still flooring the gas?
Old Jun 12, 2009 | 04:11 PM
5150DS's Avatar
Press on brake pedal really hard, then press on gas and rev engione to 3500 rpm, release brake. (for track use only)
Old Jun 12, 2009 | 04:19 PM
MJION's Avatar
Fist 12 MPH is AWD after that it converts to rear wheel.
You can however pull a fuse and make it RWD all the time, although I am not sure if this makes it any easier to peel out or if it gives faster intial gains.
But yeah you are right from my experience higher gains past 3500 rpm's.
Hard to pull out from a dead stop with out using the break and slamming the gas..
Old Jun 12, 2009 | 04:24 PM
canucklehead's Avatar
spinning tires is a function of power, but more importantly traction. i used to be able to lay black strips with my old honda civic but it had skinny little donuts for tires. you want good traction so you can put the power down to the ground, resulting in acceleration. your summer UHP tires are probably a soft compound, plus you are AWD. i'm afraid you'd need a lot more torque than in stock form to lay 4 black strips.
i can spin my tires if i wanted to (i'm 6mt rear drive). but then again, why would i want to?
Old Jun 12, 2009 | 05:12 PM
evolver's Avatar
Even more so it is a function of maturity
Old Jun 12, 2009 | 05:13 PM
Wannabe6MT's Avatar
-MN G Crew-
Its AWD, your not going to spin them.
Old Jun 12, 2009 | 05:14 PM
Mustang5L5's Avatar
You know your car is AWD right?? Gonna be pretty hard to spin the tires. You might be able to do it in the snow, with VDC off...but if you are expecting to do a F&F style AWD drift with a stock G35x, you are sorely mistaken.
Don't try to neutral drop or floor it while you hold the brake down either. Not gonna work so spare your car the abuse.
Old Jun 12, 2009 | 05:18 PM
excellent point. i assume the OP is well under 20yrs.
Old Jun 12, 2009 | 06:52 PM
RADIOGUY21's Avatar
yeah...gonna have a hard time lighting them up with the AWD model.
but spinning tires = wasted power anyway.
Old Jun 12, 2009 | 07:23 PM
ttrank's Avatar
Grocery getter
I don't have any problem with spinning my tires. Maybe you just need more power.
Old Jun 12, 2009 | 07:57 PM
Mustang5L5's Avatar
A good chunk of this site prob is under 21 I'd bet.
We were all young once. I did some stupid crap in my younger days.
Old Jun 12, 2009 | 08:15 PM
TurTLe*'s Avatar
i couldn't spin them at the track, the car rather bogs down then spin tires @ 3500 rpm
Put some bald tires and you can.
Old Jun 12, 2009 | 08:25 PM
Mustang5L5's Avatar
Mine doesn't spin at all. I rev to 3000 and floor it and it just goes.
Vid of one of my runs
