Compression Rods
Old Jun 17, 2009 | 05:39 PM
bert039's Avatar
Originally Posted by Tollboothwilley
You can replace just the bushings. Simply take off the compression rods, use a hydraulic jack and press the old out and the new in. Riverside Infiniti sells the bushings. So does www.infinitipartsonline.com which is Infiniti of Peoria.
What kind of hydraulic jack exactly? Pics or anything?
I'm starting to hear that crunching noise in the front now too.
Old Jan 8, 2010 | 06:13 PM
infinitiparts's Avatar
The part # for the RWD compression rod bushings are 54570-AC70A. The AWD compression rod bushings are 54570-AC71A. They are about $15.50 per bushing. One car will require two bushings. Plenty in stock at www.Infinitipartsonline.com
They have to be pressed in using an arbor press. Possibly a good ball joint press.....
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
yosip1115
16
Sep 28, 2015 04:14 PM
