please help. My car does not drive over 5mph
Old Jul 3, 2009 | 11:16 AM
eye.em19's Avatar
The gas pedal on my car is not working. I put it in drive and it goes up to 5 miles an hour and the same thing happens in reverse. This has never happened. In the dash it show SLIP. What could be wrong? It's an 05 sedan thank you
Old Jul 3, 2009 | 11:31 AM
DaveB's Avatar
Anything (wheels, modifications, alarms, etc) done to the car? Were you messing around under the hood?
Old Jul 3, 2009 | 11:37 AM
eye.em19's Avatar
I did change my brake pads about two week sago
Old Jul 3, 2009 | 11:50 AM
eye.em19's Avatar
i'll just take it to nissan thanks
Old Jul 3, 2009 | 05:07 PM
j 4 lD's Avatar
Wow, let us know what the prob is.
Hope you get it fixed.
Old Jul 3, 2009 | 05:12 PM
j 4 lD's Avatar
Did u check if the parking brake is on btw?
Old Jul 3, 2009 | 06:57 PM
G SEDAN's Avatar
car is in limp mode.....get it checked out at the dealer (if still in warranty), roadside assistance should come and tow you.
Old Jul 3, 2009 | 09:03 PM
350GT-R's Avatar
are you trying to say he bought his car handicapped? lol
Old Jul 3, 2009 | 09:11 PM
G SEDAN's Avatar
..................june 2009 join date....I'm not surprised
Old Jul 3, 2009 | 10:16 PM
thescreensavers's Avatar
Mr.202?
here is a good definition it will explain what "Limp Mode" is
Your engine management and maybe even your transmission is controlled by the ECU. As you know, all computers crash, all software has bugs, and mechanical equipment fails. As such, many ECU units are fitted with a 'limp home mode'. When it detects that something semi-serious is wrong, it enters the limp mode, which means that the engine won't rev beyond a pre-programmed speed, you can't accelerate very fast, or you may indeed be speed-restricted to 40 mph or similar. The transmission may even stay in one or two gears. Bad? Well, no, not really: The alternative would be to either let you drive at regular speeds, with the danger of letting you trash your car (expensive repair, means happy repair people, but angry driver), or stopping you from going anywhere (expensive recovery and stranded on the side of the road means happy recovery company, but angry driver).
This happened to my dads Q45 once but it was just a software bug. he was just limited by rpm.
Old Jul 3, 2009 | 10:19 PM
j 4 lD's Avatar
hm, never heard of limp mode before.
Old Jul 3, 2009 | 10:38 PM
vash_g35's Avatar
Originally Posted by thescreensavers
When it detects that something semi-serious is wrong, it enters the limp mode, which means that the engine won't rev beyond a pre-programmed speed....
^^^Thats the simplest and shortest answer!
Or others calls it "fail safe mode"
Old Jul 4, 2009 | 12:30 AM
lexusk8's Avatar
This happened to me before with my previous vehicle (Lexus ES). Couldn't go more than 40 mph on the highway. Turned out that the solenoid in the transmission was faulty, which pretty much screwed up the whole gear shifting of the transmission in making the engine run properly.
Old Jul 5, 2009 | 08:28 PM
eye.em19's Avatar
Well the car is not mine, is my sisters. It turns out that it's still under warranty and the dealer sent a flat bed tow truck to the house and picked it up. Funny that the car had no power and couldn't go up. I'll post what the prob was for future reference.
Old Jul 5, 2009 | 08:44 PM
eye.em19's Avatar
It had SLIP, VDC OFF, SERVICE ENGINE SOON lit up on the dash
