Just another G sedan representin' with some new brakes. . .
Old Jul 5, 2009 | 09:10 PM
liukai's Avatar
hope this isn't the wrong forum to be in (i was thinkin' maybe i shoudl put this in the brake forum, but i'm proud of owning a sedan so i'm posting it here!)
just finally finished installing my akebono bbk. . .used G2 paint system to paint them red, than put on "infiniti" vinyl decals, and sprayed over with high temp caliper VHT clear coat for added protection. . .these were a nightmare since my 18" OEM coupe rims did not clear the calipers, and my currently installed 19" rims did not have the correct offset. . .so 10MM ichiba spacers were installed in the front to get that right. . .only lingering problem are two things. . .the threads on one of the studs that came wiht my spacers are jacked up (gotta get a replacement), and i'm hearing this rubbing on my front left brake system. . .i'm pretty sure its the pads against the rotors, but it sounds pretty bad, so i'll have to do more R&D and get it fixed later since i'm outta town for the next week. . .anyways nothing too unique, but i love the look!
My 1.5mm of clearance. . just barely made it!
Old Jul 5, 2009 | 09:24 PM
Mustang5L5's Avatar
Damn that's a tight fit!
Looks good
Old Jul 5, 2009 | 09:33 PM
Hotdawwgman's Avatar
DAMN!!!!! Looking so good!
Old Jul 5, 2009 | 09:56 PM
blue22flames00's Avatar
wow...that fitt is tiiighhtt...looks good though
Old Jul 5, 2009 | 11:22 PM
liukai's Avatar
yea, my heart skipped a few beats as i was putting the wheels on. . .cause i did NOT want to re-install my old brakes!
Old Jul 5, 2009 | 11:25 PM
G35Papa's Avatar
**** that's close! I like it
Check to make sure the dust shields up front are not hitting/rubbing on the rotor. That is usually what happens when you go bigger up front.
Old Jul 5, 2009 | 11:27 PM
deuce3333's Avatar
Could you give us a little review of how the perform? Thanks. Looks good. thinkin of this down the road.
Old Jul 5, 2009 | 11:32 PM
deuce3333's Avatar
Also what the specs on ur wheels?
Old Jul 5, 2009 | 11:35 PM
liukai's Avatar
thanks for the props. . .YES, dust shields also immediately came to my mind, i'll definitley be ready to hack off anything that gets in my rotor's way!. . .i will certainly make a review once i get everything fixed soon hopefully. There's actually a few reviews already on this setup (i think in the brake/suspension Tech forum), all were extremely positive (reason why i got a set).
Old Jul 5, 2009 | 11:38 PM
liukai's Avatar
rims are 19 x 8.5" . . .with i believe a +35mm offset. . .requiring me to get 10mm wheel spacers up front. . .the rears clear with no problem. . .
Old Jul 6, 2009 | 02:27 AM
G SEDAN's Avatar
looks good. did you spray on the G2 or you brushed it on?
Old Jul 6, 2009 | 02:51 AM
4drmadness's Avatar
looking good man. where did u get the akebono kit from?
Old Jul 6, 2009 | 02:52 AM
CandlestickPark's Avatar
ill Sedan
Very nice man, congrats!
Old Jul 6, 2009 | 08:51 AM
GGGGGGGG's Avatar
Beautiful!!!!
Old Jul 6, 2009 | 09:53 AM
three.five's Avatar
Looks HOT! Way to represent the SEDAN!
