Updated Drag Strip Times
Old Jul 25, 2004 | 06:07 AM
bosssho's Avatar
Re: Updated Drag Strip Times
LOL...after the CAI...she was all done...maybe a Grounding kit for it, but that's that. She's afraid to even drive my car at this point. ;-)
John
03.5 G35 5AT 14.2 @ 100.36
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
350 Z 170F Thermostat
02 Maxima SE 4AT 14.5 @ 95
87 Mustang GT 13.2 @ 107
Old Jul 25, 2004 | 06:10 AM
bosssho's Avatar
If you are after looks the rims I guess...but if speed is what you after looks can always be overcome by the sound of the engine or exhaust...lol
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 25, 2004 | 02:41 PM
iLLG35's Avatar
NY G-Squad G Race Driver
"Have MM work some magic for ya down their lonestar!!! ;-)"
Boss what did you mean by that lol ?? Also I have rims for my looks and "performance" rite now but wanted track rims, I asked what would be better. A set of track rims over stock rims or a plenum?
Martin
2003.5 BS G35
Nismo Aero/Sport Package
Injen CAI
B+G Springs
ADR M-Classic 19's..
Old Jul 25, 2004 | 10:45 PM
bosssho's Avatar
MM = Mike Murillo...a famous guy to us Mustang owners from back in the 90's. He dynoed the guy in TX's car...
If you already have your "looks" rims, but would like to know what's better for performance, IE, light weight rims and good tires vs. a Plenum...go for the light weight rims and tires right now b/c if you do the plenum you should do the Techno Square reflash too...and that's another $520.00....
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 26, 2004 | 02:22 AM
iLLG35's Avatar
Ohh I see, thats true :/ i think i'll skip the plenum since I wont have money to get the ECU. The TS ecu just pulls everything together basically rite??
Martin
2003.5 BS G35
Injen CAI
B+G Springs
Old Jul 26, 2004 | 08:14 AM
G35_TX's Avatar
Yep. Fastest mustang at the time. Not sure if he still is though.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, Stilen CAI
Track: 14.32 at 98.79 mph 2.2032 60ft
Dyno 07-07-04 - 234.2 hp & 233.8 tq
http://www.g35world.com
Old Jul 26, 2004 | 08:56 AM
bosssho's Avatar
The TS Reflash pulls stuff together, but that's imperceptable really...the coolest thing that it does is not lean you out after your mods, it increases your top speed so if you live somewhere where 160 is possible have fun, and the coolest thing I have found is it turns Manual Mode into a true standard almost with an increased rev limiter...my car pulled all of those insane 100.3 mph trap speeds in manual mode...only 97+ in 4...oh, and if you hold it you can actually cross the traps in 3 which was never possible b/f. I really need a set of drag radials now to test out all the power and traction.
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 26, 2004 | 12:45 PM
BobbyD's Avatar
bosssho,
I'm a bit confused, your updated times(slip provided) states 14.37 @ 100.36
In your sig you have 14.2 @ 100.36
Is that a combination of your best et and mph from separate runs or did you actually run that exact time and mph?
Thanks
2003 G35 Sedan 6MT
14.13 @ 99.55 (stock)
Old Jul 26, 2004 | 02:14 PM
bosssho's Avatar
You are correct...I actually have two time slips posted, one is the time and speed you mentioned which was my best mph and the other was the best time that day which was 14.31...14.29 is still my best ET...so I combined the two.
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 26, 2004 | 03:04 PM
BobbyD's Avatar
Hey, that's cheating[img]/w3timages/icons/wink.gif[/img]
2003 G35 Sedan 6MT
Old Jul 26, 2004 | 03:24 PM
bosssho's Avatar
Says who? lol
That's actually the on line dyno formula to figure out HP...it's also accepted at other forums so I was running with it rather than have two different lines with my best time and best MPH.
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 26, 2004 | 04:06 PM
BobbyD's Avatar
<hr></blockquote>
What formula are you using to figure out hp? You took two variables from separate runs which is not accurate at all. I've heard of correcting times for sea level if your running in higher altitudes, but that's more like "could have" run in ideal conditions. The general consesus is what ever your slip says is what you achieved. Your sig is misleading because you did not run 14.2 @ 100.36 ! No offence, your car is quick but your info is fudged!
2003 G35 Sedan 6MT
Old Jul 26, 2004 | 04:25 PM
bosssho's Avatar
The corral.net asks for your best times and mph and your vehicle weight...14.31 or 14.29 at 100+ = Zero difference in power, but a hair of difference in traction off the line...the 60' times are the only reason I did not run a 13.9-14.1...and remember it was 90F when I got there and still 85F when I left...I don't feel I am fudging anything and I certainly don't take offense...you had a valid question and I totally see why you asked it...we just have a difference of opinion on it which is fine.
John
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 26, 2004 | 04:42 PM
Typhoon's Avatar
Bosssho: Is that the same logic you used for the other cars in your sig?
I kind of understand your reason. But, I think combining two different runs are misleading. I think you should footnote it. Just my$0.02 (not that you asked)
I had the same with my Typhoon back in 94. But, I picked the low ET run over the MPH run to list on the forum.Bosssho: Is that the same logic you used for the other cars in your sig?
03.5 G35S 5AT - Desert Platinum/Graphite/350Z Tube/Clear corners/HG kit/20% Tint
Old Jul 26, 2004 | 04:53 PM
  #30
bosssho's Avatar
No, and I changed it back to 14.2 @ 96.4 b/c explaining this was way more effort than it should have been. The quickest time is what ultimately counts.
John
03.5 G35 5AT 14.2 @ 96.4
10 Wire Grnd Kit
K&N CAI w/Injen HS
UR UD CP
NISMO Mid Pipe
Crawford V 5.0
TS
