Back seats out HELP !!
Old Jul 21, 2009 | 05:21 PM
Jacob_USA's Avatar
Im wondering how to take the back seats out of my G35 sedan 06. Can anyone help me out ?
Old Jul 21, 2009 | 05:38 PM
xratedg's Avatar
Sit in the back seat and feel around where you would typically put you gum, under your seat. Then pull the tabs out about an inch and the seat will unlock. Hint, there's 2 tabs.
If you don't know what I mean, search and you will find the answer.
Old Jul 21, 2009 | 05:44 PM
thescreensavers's Avatar
Mr.202?
The 2 tabs underneath each seat on the side? I felt this I though it was for the child seat. How easy is it to back in once you take it out?
Old Jul 21, 2009 | 05:54 PM
6MTFTW's Avatar
If you're just removing the seat bottom, it's a 1 minute install/uninstall.
If you plan on removing the seat backs, it's a little more involved. Download an FSM for step-by-step directions.
Old Jul 21, 2009 | 06:57 PM
CandlestickPark's Avatar
ill Sedan
To remove the bottom portion there is a tab in the middle at bottom of the seat where the leather meets the carpet. Pull the tab out and lift up. There is a tab on the drivers and passenger side.
To remove the seat back you'll need to remove two bolts at the bottom of each seat back on the left and right (4 bolts total IIRC its 12 or 14mm). Push up and pull out at the bottom of the seat back.
Hope this helps.
Pcruz
Aug 12, 2015 07:46 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
brian_z
Jul 20, 2015 01:30 AM
