What alignment are you running on your sedan?
Old Aug 16, 2009 | 03:33 PM
jakeup93's Avatar
Regardless of what you guys are running (350Z susp, Tokico's, Tein, etc.), are you running the stock or close to stock alignments specs or have you guys changed to the 350Z's or coupe's...seeing as they are more aggressive?
Old Aug 16, 2009 | 05:11 PM
thehitt's Avatar
Front
Caster 8.5
Toe .05 per side
Camber -1.5 per side
Rear
Toe .08 per side
Camber .8 per side
Old Aug 16, 2009 | 07:16 PM
CandlestickPark's Avatar
ill Sedan
Alignment specs, what are those...haha! I'm running -2.75 camber on all four corners, front camber is the natural camber at my ride height and the rears are dialed in so the tire is right at the fender.
Old Aug 16, 2009 | 08:16 PM
TurTLe*'s Avatar
Well most people choose to run at a certain spec either for racing purposes or for tire fitment, there are a couple more reasons.
But if you dont have any reason. I would just aim for stock specs, or the closes they can bring it to. if you have a full SPC kit, you should have 90% of the fields in Green if not all.
Toe and camber are what kills tires.
Old Aug 16, 2009 | 09:41 PM
Texasscout's Avatar
That's what I did. Put on the Z springs and then told the guy to get it as close as he could. It's within 1/2 deg of spec in the front and 1 deg in the back.
Old Aug 16, 2009 | 09:52 PM
G SEDAN's Avatar
-1 front, -1.5 rear
Car is sitting pretty low, but I got the SPC F/R camber kits to get em back in spec.
Old Aug 17, 2009 | 02:17 AM
4drmadness's Avatar
^ pvssy camber, hahah
Old Aug 17, 2009 | 02:33 AM
G SEDAN's Avatar
pvssy camber allows me to buy sick **** tires (Michelin Pilot Sport 2) and not have to replace them every 6 months. It also allows me to buy a BBK which you do not have
ohhhhhhhhhhhhhhhhhhhhhhhh
Old Aug 17, 2009 | 02:58 AM
The Stimulation's Avatar
I dunno full specs, but all I know is I have-3.5 camber in the rear and need more.
Old Aug 17, 2009 | 07:08 AM
TurTLe*'s Avatar
^ judging from that picture, its by choice tho.
G sedan, i think you can run stock camber and be ok. I ran those 265/40 PS2 @ stock height no issues, I'm running now lowered but obviously the car cambers itself when you go lower.
Old Aug 17, 2009 | 12:27 PM
Not necessarily by choice, it's more because I have to...here's a larger pic so you can see why.
Fitting a 10.5 is not quite the easiest thing to do, which is why it's still not completely finished.
Old Aug 17, 2009 | 12:38 PM
cremaster's Avatar
-2 on all 4 corners. i'm too cheap and lazy to buy a camber kit.
Old Aug 17, 2009 | 01:00 PM
DaveB's Avatar
350Z springs in the front, coupe springs out back
Front camber: 1.0
Rear camber: 1.1
Front toe: 0.16' total
Rear toe: 0.22' total
I told the shop to set my front toe to max spec as it's one of the ways Nissan fixes the front tire feathering issue that plagues the Z (and G on Z springs). I didn't realize until about a week after the alignment that the shop also set my rear toe to max toe-in. On the OEM 215/55R17, the handling is fine, but with my wider 18X8 235/45 summer tires, the car can be darty, but it has amazing lateral grip and turn-in on the auto-x course. I am going to dial back a bit of the rear toe and hopefully reduce some of the dartiness.
IMO, aftermarket front camber arms are really not that necessary if you're toe is on-spot. I'm running a 9.5" wide wheel and using stock camber up front. Save your money, only buy a rear one if needed.
Old Aug 17, 2009 | 01:04 PM
cremaster's Avatar
levin, do you have pics of your new wheels?? yeah, i haven't been on driver for about a week haha
