Anybody have battery drain problems on 2005 G35 Sedan?
Old Sep 3, 2009 | 11:06 PM
jbracco@insight's Avatar
Anybody out there had any electrical systems problems?
I have a dead battery, uncertain if this is due to a battery drain/electrical problem. I have seen a few posts on 2003 G35's that have this problem. The problem seems to be related to the radio/BOSE amp. Anyone aware of this in the 2005 G35?
Old Sep 4, 2009 | 01:57 AM
6spSEDANFTW!'s Avatar
r u 100% sure its a drain and not a bad battery?
Old Sep 4, 2009 | 03:51 AM
NAT@FFTec's Avatar
are you still on the original battery? if so, it most likely needs replacing
Old Sep 4, 2009 | 08:16 AM
Mustang5L5's Avatar
Hook a digital mutlimeter up that can read DC amps in series with the battery and see how many Amps of draw you have with the car off
Old Sep 4, 2009 | 10:58 AM
RADIOGUY21's Avatar
yeah if you are still on the factory battery I would recommend replacing it. Im still on the OEM and will be replacing very soon.
Old Sep 4, 2009 | 10:20 PM
I was concerned because my car suddenly began having problems, I checked the battery and it had a bad cell. I just bought the car used from the infinity dealer 3 weeks ago. I dropped it off today and the Dealer replaced battery for free. My concern was due to some of the strange things that began to happen when the car would not start (chirping from the security system/keyfob). I did a quick internet search found some common problems with the 2003 G35 and the BOSE amp as a possible cause for battery drain. Just wanted to see if anyone had problems with a 2005. Hopefully was simply an old battery. I guess I will find out over the next few weeks. Thanks for the advice.
Old Sep 4, 2009 | 10:46 PM
Heist.'s Avatar
yeah your battery just probably took a dive. Give it a month and see what happens.
Old Sep 4, 2009 | 11:48 PM
Texasscout's Avatar
I recomend an Optima "red top" in the 34R size.
Old Mar 15, 2011 | 01:50 AM
ridinG's Avatar
Yes, I have this issue on my 05! 650 mA draw with car off! Please update if you have a fix!
Old Mar 15, 2011 | 03:32 AM
NMG-4's Avatar
05 and never have a problem,maybe just old battery.
Old Mar 15, 2011 | 10:06 PM
NFSP G35's Avatar
? = 2B || !2B
Indeed!
If the draw is unusually high, you have an electrical problem. Start pulling fuses until you trace it down (start with the radio and hvac system)
If the draw is only very very slight (clock and various computers do take a tiny amount) then the problem is your battery.
laksjd84
Feb 28, 2026 01:58 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
attarday
Jul 15, 2015 04:03 PM
