Idle Air Volume Learning (Throttle Position Learning)
Old Sep 17, 2009 | 11:08 PM
pinky1121's Avatar
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
"Before the next procedure, is the ignition stays on "on" after the 3 seconds and turn it to off and to the next step or just leave it on. I am confuse about this step. please help..
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
Silver tiburon
Sep 4, 2015 07:17 PM
Kicknshift
Sep 3, 2015 09:35 AM
